558 threads found!
steveshanks | 3 | 421 | ||
steveshanks | 6 | 207 | ||
steveshanks | 2 | 301 | ||
steveshanks | 4 | 167 | ||
steveshanks | 3 | 148 | ||
steveshanks | 2 | 192 | ||
steveshanks | 4 | 179 | ||
steveshanks | 1 | 377 | ||
steveshanks | 1 | 383 | ||
steveshanks | 0 | 150 |
(none)
steveshanks | 0 | 143 |
(none)
steveshanks | 1 | 151 | ||
steveshanks | 1 | 143 | ||
steveshanks | 4 | 188 | ||
steveshanks | 2 | 209 |
3,036 comments found!
Thread: OT- Do you still listen to radio? | Forum: Poser - OFFICIAL
BBC Radio 2 through DAB is on all day for my Cockatiel (He hates seagulls so it masks there sound) occasionally i put on internet radio through an Ipad to get a decent Jazz station (None in the UK)...........Steve
Thread: An idea for an outfit for the Vickies | Forum: Poser - OFFICIAL
Thread: Make Conforming Clothing for Poser Figures | Forum: Poser - OFFICIAL
Yep as Bob says.
I use Cinema 4d and my workflow is, modeling in Cinema and every material is made a seperate object then exported into Roadkill for mapping (A huge thanks to EnglishBob for his tutorial and putting me onto this great app), then bring everything back into C4d, assign materials and check, then export out, open in uvmapper arrange the map and join everything into one group ready for AutoGroup Editor.........Steve
Open it up in UVMapper and you can assign materials in there without affecting your grouping.
To do this, select a part of the model, lets say the zip area, then go Tools, Assign to, Material, then type in your material name and repeat for other materials..........Steve
Thread: poser options for visually impaired? | Forum: Poser - OFFICIAL
I had a similar problem before i had my lenses replaced, I used a magnifying glass for a long time, but you can hack the the ui file to make the text bigger.
Go into
Poser Pro 2014/Runtime/ui
and find the parmDialPrefs.xml file
Open it in a text editor, I recommend Editpad Lite, because i know it works ;o) and go Edit- Search and replace, Do a search for text and you should findÂ
textSize="12"
Copy that into the search text box and then add something like
textSize="18"
into the replace text box, then hit replace all and save, open Poser and see how you like it, if its not right close poser hit undo in Editpad and try another number till its right, If you get stuck PM me and we can swap emails so you can send me youurs and i can do you a few versions to try.........Steve
Thread: Advice needed... | Forum: Poser - OFFICIAL
Did you apply the AddDeformers pose to the clothes (Found in your Roxie Speciality Poses)
Thread: O/T Making 3d from a 2d Photo | Forum: Poser - OFFICIAL
Thread: Major Poser World Problems | Forum: Poser - OFFICIAL
Thread: Hahahaha.. What happens when... | Forum: Poser - OFFICIAL
Thread: A little OT: Docking Station | Forum: Poser - OFFICIAL
Have a look at this image, it'll tell you what drive you have then buy an enclosure to match, they are dirt cheap and dead easy to put together AND much cheaper than paying your guy (I'm guessing :o)........Steve
Thread: What's the easiest way to create morphs in clothes? | Forum: Poser - OFFICIAL
Do you mean in Poser or another app, i've done it in Cinema 4d many a time but no idea in Poser......Steve
Thread: Working With OBJ Files Between Poser 9/Cinema 4D 13.0 | Forum: Poser - OFFICIAL
Like Timberwolf says, you need riptide, make sure your import and export scales are set to 1000 and you should be good to go........Steve
Thread: How do you make a hybrid clothing item? | Forum: Poser - OFFICIAL
