21 threads found!
taerin | 3 | 96 | ||
taerin | 7 | 139 | ||
taerin | 1 | 28 | ||
taerin | 4 | 111 | ||
taerin | 5 | 153 | ||
taerin | 7 | 165 | ||
taerin | 3 | 93 | ||
taerin | 7 | 169 | ||
taerin | 6 | 138 | ||
taerin | 4 | 160 | ||
taerin | 9 | 152 | ||
taerin | 3 | 89 | ||
taerin | 16 | 93 | ||
taerin | 0 | 6 |
(none)
taerin | 3 | 18 |
47 comments found!
Sorry 'bout the lack of pic in the previous posting, here's one now:
See that pile of gifts in the second car? (Yeah, I'm still adjusting the car's placement, I know it's up under the engine.) That's the pile I was referring to.
I do like the idea of rendering the gifts separately for the final image and posting them into the final shot. If I can't figure out another way around this, I might just do that. Thanks!
Thread: Update to Bryce 6 Development | Forum: Bryce
Two other quick wishes for Bryce 6:
Simple example: create a thin positive disk and use a negative elongated cube to carve a square all the way through the middle. Then 'compress' that group, so it turns into a single neutral mesh of a disk with a square hole in the middle, no negative boolean object would remain.
Thread: the largely uninspired stuff i've been rendering this week : / | Forum: Bryce
Thread: Midwinter Inspirations WIP 5 | Forum: Bryce
I think this is lovely, and it looks soooo cold! :-)
The only recommendation I can think of is that the solid snowflakes close to the camera have a matte material, and I tend to think of snowflakes as icy-transparent. You could re-texture them and just plop-render those areas, to avoid a long re-render of the whole scene.
Two other questions:
Thread: Jester tex for M2? | Forum: Poser - OFFICIAL
Has anyone else seen a jester texture for Mike 2? I really like the one in Serpentis' Jokers Wild pack, but that's for Vicki 3. Thanks...
Thanks, Laurie. Unfortunately, that link is broken. Are you able to access it right now? I'll try again in awhile, in case they're just having some sort of server issues.
Thread: *********** April Challenge..... VOTE HERE ************* | Forum: Poser - OFFICIAL
Thread: Your chance to appear on *EVERY* Renderosity page! | Forum: Poser - OFFICIAL
So, if I understand the rules, to enter the contest we have to buy the 'PhenixAmerican' font?
Thread: Stalk of wheat model? | Forum: Poser - OFFICIAL
I've already tried there, with no luck. :-( Hiram, there's no rush, and if you'd just like to give some general instructions, I could probably do it myself. I'm used to modelling in Bryce with heightmaps and booleans, and I can do a little in Cinema. I'm thinking if I create spline outlines for the... seed thingie part, and make a loft nurb, then it would just have to be duplicated enough times. Am I on the right track?
Thread: 3Ds Max textures... | Forum: Animation
Well, when I'm exporting for use in Bryce, I choose OBJ as my format. The textures that I've used in Poser are referenced in a .mtl file that gets saved in the same place as the OBJ. When I then import the file into Bryce, it knows which textures go where, and if the texture files themselves are in the same folder as the OBJ, they load in with the object. So I guess what I'm saying is that the textures you have now, or could download from Freestuff or wherever, should be able to be used in Max. Hope that helps. - taerin
Thread: How to make hair invis, but not beard? | Forum: Poser - OFFICIAL
Bless you, O Master. That worked perfectly. :-D I just hope it wasn't in a FAQ somewhere that I missed... And while I have the eyes of anyone reading, it seems that you can only add lights from the Lights library. I thought that applying a lighting preset changed the number, color, location, etc of lights in your document. Apparently, that's not the case. I saved the default 3-light setup, but when I reapplied it after using a set of nearly 50 lights, the existing ones didn't go away. Is there an easier way to remove lights, other than selecting them one by one and clicking the tiny trashcan? Thanks again, - taerin
Thread: The Future depends on Praxis22 | Forum: Poser - OFFICIAL
And I'll tell ya, the green lady's face reminds me of the newest potential Slayer on Buffy - the tall, very thin one that goes to school with Dawn. (dorkmode off now) :-)
Thread: Lighting on an object but not on others around? | Forum: Bryce
Thread: File size reduction advice? | Forum: Bryce
