We couldn't find any threads matching the specified search criteria.
2 comments found!
I should have mentioned that in copying the morphs do them in reverse order (ie., last one first).
Thread: Sorting morphs | Forum: Poser Technical
I found that by loading the cr2 into "Morph Manager" into both the left and right windows I was able to reorder the morphs. First delete all target morphs from the left window. Then copy the morphs from the right window in the desired order. Finally save the left window once you are sure it is as you like it. I would suggest that you save it with a slightly different file name at first so as not to overwrite the original cr2 file. If all works out, then replace the original cr2 file. I couldn't find an easier way to do it
