2 threads found!
Posted May 03, 2002 at 1:41 pm | Forum: Poser - OFFICIAL |
vmiller | 4 | 167 |
2002 May 03 4:14 PM
Posted May 02, 2002 at 7:51 pm | Forum: Poser Technical |
vmiller | 4 | 92 |
3 comments found!
Aaron....You the man!! You solved the problem! If you have TO MUCH virutal memory, then Poser doesn't work right. Seems kind of backward doesn't it? anyway, I reduced my virtual memory from 3 gigs on one drive plus an addition 3 gigs on a second drive to 990 megs and all it well. VMX
Thread: HELP! Figures won't show in posing window! | Forum: Poser Technical
A suggestion from another forum solved the problem! If you have TO MUCH virutal memory, then Poser doesn't work right. Seems kind of backward doesn't it? anyway, I reduced my virtual memory from 3 gigs on one drive plus an addition 3 gigs on a second drive and all it well. VMX
Yes it is with all figures. I have deleted the rsr files, rebooted, restarted, but no joy. I have uninstalled the program, gone through the registry, reinstalled the program, still no good. I have version 4, with the 4.03 update. Doesn't help to install the poser plus package. Things work fine on another, older computer.
VMX
Thread: Help! Can't see the figure in the posing window, but it is their | Forum: Poser - OFFICIAL
