We couldn't find any threads matching the specified search criteria.
1 comments found!
<drages posted at 2:48PM Fri, 06 December 2019 - #4370293
Glitterati3D posted at 12:07PM Fri, 15 November 2019 - #4370277
Hi drages,
Let's start at the beginning, please.
What version of Poser 11 are you installing and where did you get the copy you are trying to install?
If you are not using the Bondware/Renderosity version of Poser, it will behave exactly as you are seeing. All Smith Micro versions of Poser have been "turned off" at the SM servers because Bondware purchased Poser.
So, if we can, let's make sure you have a valid, working copy of Poser that you are trying to install.
Hey! I downloaded the final version from here as 11.2. I start poser, after the loading banner, the programs opens but only the background UI and after some seconds it crashes to desktop. I will try to use uninstaller program to clean old smith micro version. Thx!
I have the same issue on Windows 10 Home edition German (PC: i7-9700K, 32GB RAM, NVIDIA 1070Ti) with the version Poser Pro 11.2.319 as of 11-13-2019 12:11 pm downloaded from here (https://www.posersoftware.com/downloads). - It opens and displays the UI Background, then crashes.
Specialities of my installation:
I tried different approaches: installing as normal user or admin; I also did an clean uninstall using the suggested geek uninstaller and started all over again
Any further suggestions and ideas where the problem comes from and how to solve it? @drages did you finally manage to get it working?
Thanks in advance!
Thread: Poser Pro 11.2 new install crashes on start up. | Forum: Poser - OFFICIAL
