3 threads found!
wealthychef | 2 | 2077 | ||
wealthychef | 7 | 309 | ||
wealthychef | 1 | 2124 |
5 comments found!
Found a solution thanks to http://mcngraphics.com/thelab/blender/connect/
def FindRotation(ep1, ep2):
ep1 = numpy.array(ep1)
ep2 = numpy.array(ep2)
center = ep1 + 0.5 * (ep2 - ep1)
ep2new = ep2 - center
r = numpy.linalg.norm(ep2new) # radius of sphere
theta = math.acos(ep2new[2]/r)
phi = math.atan2( ep2new[1], ep2new[0])
return (0,theta, phi)
Thread: Blender python: Creating a cylinder given two endpoints and a radius | Forum: Blender
Tough one, eh? :-) I've googled all over the place, and I've found some code, but it does not work. that is, the resulting quaternion, when used as obj.rotate_quaternion, does not result in properly rotated cylinder with ep1 = (0,0,0) and ep1 = (0,100,0)
vec = numpy.array(ep2) - numpy.array(ep1)
if not vec[0] and not vec[1]:
return (0,0,0)
print ("vec: %s"%str(vec))
Z = numpy.array((0,0,1))
kcostheta = numpy.dot(Z, vec)
k = Length(vec) # sqrt(Length(vec)^2 * Length(Z)^2) = Length(vec)
Q = Quaternion(numpy.cross(vec,Z), kcostheta+k)
Q.normalize()
print ("kcostheta: %f, k: %f, Q: %s"%(kcostheta, k, str(Q)))
return Q
Thread: Newbie trying to put up a background image | Forum: Blender
Quote - Input>Texture Coordinate (Generated, Window, or Camera) plugged into Vector>Mapping, which is then plugged into the vector socket on your image texture. X and Y scaling settings should do the job. Other adjustments of interest are Z-rotation and X and Y location.
Sounds excellent, I'll try that too. What is working very well in my case now was to create a hexahedron (anisotropically scaled cube) around my scene and texture an image onto it. Gives exactly the effect I want for my project.
However, this does NOT tile the image. Anyone know how I can tile the image acroos the background instead of having a huge image?
