13 threads found!
xuu4u | 11 | 549 | ||
xuu4u | 11 | 273 | ||
Advisories: nudity
xuu4u | 15 | 507 | |
Advisories: nudity
xuu4u | 14 | 719 | |
xuu4u | 3 | 147 | ||
xuu4u | 8 | 389 | ||
xuu4u | 2 | 282 | ||
xuu4u | 7 | 448 | ||
xuu4u | 10 | 327 | ||
xuu4u | 2 | 98 | ||
Advisories: nudity
xuu4u | 3 | 257 | |
xuu4u | 1 | 76 | ||
xuu4u | 7 | 337 |
69 comments found!
Thread: Gallery Albums Question and other Failures | Forum: Community Center
some time has passed and i woul like to ask you wether there is any news about my concerns ?
in my above post ([@4250292](https://www.renderosity.com/mod/forumpro/?thread_id=2898616#msg4250292)) i tried to describe exactly and reproduceable how the bug (replacing pictures in tutorials) happens.
was this understandable and useful ?
I also have created and uploaded Part3 of this tutorial.
Setting up debugging of pythonscripts inside Poser has become a lot easier with PPro2010 / 2014.
The problem here is that if i look into my tutorials section, Part3 has the
"(pending approval)" state since the day i uploaded it:
xuu4u on 8:59PM Mon, 18 January 2016
as a comparison my last 2 freestuff items was processed in less then 2 hours and the new tutorial part contains only 2 text pages.
could you pls have a look at that ?
and thank you very much for taking care of my concerns
Thread: Uploaded | Forum: Freestuff
hmm, dont know why but i am not allowed to edit my above posting to fix it as "PoserG2" .... ?
Hi Jules, i mentioned that that clearly in the short description of the download section. and i will change it above for clearness, thank you.
Thread: Poser Girls Lineup comparisons | Forum: Poser - OFFICIAL
Interesting news about Pauline in this thread. ty all for the infos.
(even its a bit offtopic)
As my poser experience (since Poser5) tells me, Poser11 will be stable after SR3, hopefully for the ppl using Poser11. Personally i will pause again for 1 to 2 Releases, like i did before, got PPro2010 then PPro2014.
Maybe SM should take more time too and produce more quality content and less initial bugs.
Releasing a figure like Pauline with such flaws is not understandable / acceptable.
(comparing the smith micro figures, positives and negatives of each.)
Well so i start with very annoing negative one and hope this does not count as offtopic.
My first issue with this figures was the ONE folder they are installed to.
Lets say you have installed the distributed figures packages of PPro2014 and take
a first look inside your content (runtime\libraries\People\Ryan or \Alyson).
Wow, you see all mixed up together, very confusing without any structure.
Its possible to clearly structure folders under runtime\libraries since Poser5 !
(provided that you don't have references inside)
But SM the Poser devlopers take you that freedom, by packing all different Ryan
Versions including corresponding .obj's and .pmds in ONE directory.
(Rember .obj and .pmd are references and should reside under runtime\geometries)
And Alyson, absolute the same. (Each directory has more than 600 MB together 1.2GB)
So tell me if you dont know these figures very well, where to start to check them out ?
Besides that, .pmd Tech should help to not copy morphs over and over again.
But what does SM here ?, they create absolute indentical copies of .pmds
with different names.
So before i was content to continue with Ryan and Alyson i had to clear out
that crap to an easy to use folder structure. Costed me about 2 hours, but now
i have the folder structure like it should came from SM. References on its place
and saved a lot of space, getting rid of this useless copies of .pmd files.
And also a clear division between Rayn and Ryan2, Alyson and Alyson2 and all of his/her different versions.
Hello Everybody
Just to mention that i uploaded my "G2 QPosePack1 Kneeling" to the rendo freestuff area.
This Package contains:
- "poser ready" folder structure.
- ReadMe.txt
21 Quality Kneeling Poses for G2 Female Figures
(OliviaG2, SydneyG2, JessiG2)
2 Material Settings for the G2 Bra and the G2 Panties (used in the Promos)
These 2 items are default Poser Clothes since Poser7 for G2 Females.
greetings xuu4u
Hello Jules53757,
using an external Editor, means write the text insidie this external Edtitor and than copy and paste to rendo ?
or is there a way to integrate an external editor directly ?
BTW, can anybody tell me, how to tell "Markdown" it should insert a simple "CR/LF" ? i format my text in "write" window via CR/LF (Beginning just a new Line by pressing enter) but in the preview after markdown processing all my CL/LFs are gone ... arrgll
WTF, srry for that, i just uploaded a Freestuff Package, then i crated a new thread under the freestuff forum to inform the comunity about it , nearly 30 minutes of work, when i was finished and wanted to post it this message came up:
Hello hopeandlove, thanks for caring about my problem. So i start to explain step by step and with detailed info to reproduce the errors.
Nr.1 Replacing a Picture in one of my tutorials. Tutorial Name: "IDLE Part2 : Debugging Python Scripts with IDLE inside Poser" Tutorial Link : https://www.renderosity.com/mod/tutorial/?tutorial_id=2223 What i want to do: Replace the Picture in Page1 with the correct Picutre. Workflow:
well at last the insert picture dialog in the forum works
Thread: Help! Name needed for new product | Forum: Poser - OFFICIAL
Thread: please help - P8 libraries palette not showing | Forum: Poser - OFFICIAL
Had some trouble with the AIR-Library too.
(Using PPRO2010 SR1 on W7 64bit Ultimate)
4 days ago, i could not anymore bring the AIR-libray back to screen.
the window was there "minimized" in the taskbar, but clicking on it had no result,
except a short flashing.
Could close it, restart it in poser , same result.
Besides the AIR-Library i use D3D's XL (prefered). So the evening the problem appeared i did'n care much about it.
Turning on my machine the next day the problem was still there.
Yeah, hunting time for the Scorpion (=Me).
With my experience, i know that often wrong settings in the initial files causes problems.
Found that:
C:UsersYourAccountAppDataRoamingLSMGUIAIR.64AAB1E9DCCE40D96A4E881F8BD26884D826DB32.1Local Storepreferences.xml
WITHOUT RUNNING POSER!
Deleted "preferences.xml" to recycle.bin for eventually later restoring, if things go worse :)
Starting Poser after that, my AIR-Library loaded normaly again.
And srry, i could not reproduce the error until now.
but the library still works fine :)
Maybe that coud help
BTW: i only once answered the qestion to windows wether poser has access to "internet"
or better said local ip adresses in the network, shortly after installation.
Since that i had no probems with that.
Disconnecting my local network from the internet has no influcence on how poser starts - wether its connected to the internet or not.
And i have another one for you - its about home-calling.
2 weeks ago, (normally i am always connected to internt,)
AIR popped up, with the friendly message it want to update itself.
Boahh nice i thougt - did i allow AIR anytime to look for updates, NO i didn't.
Because i did a complete system image one day before i let it go. OK no negative
issuses, even after sys restart.
When i installed PP2010, i saw no option wether i want AIR look for updates.
Think i should check my IP-log how often AIR called home for upd info :)
greetings
Xuu4u
srry people for the double post, somewhow rosity cutted me, cant delet first post
pls forum admin, delete my post above :)
Found that:
C:UsersUserBAppDataRoamingLSMGUIAIR.64AAB1E9DCCE40D96A4E881F8BD26884D826DB32.1Local Storepreferences.xml
or better said ip adresses in the local network, shortly after installation. Since that i had no probems with that.
Disconnection my local network from the internet has no influcence on how poser starts - wether its connected to the internet or not.
greetings
Xuu4u
greetings
Xuu4u
Thread: Tip: Utilites for Testing & Setting Up Lights | Forum: Poser - OFFICIAL
Quote - Heh, then you'd see the EnvHemisphere. My Hemisphere with image from Flicker is never visible in a render because of copyright on the image used. I use the image only for lighting purposes and it is never, ever seen. I'd have to put something else in there like the Corner Modeling room that I built for several of my images at Deviant art.
wooha, latexluv you are bending laws like a poser figures, lol.
hehe, so you think using a part of it is legal, because you cant see the image complete ?
interesting !
are sure somebody could really recognize the image, if you show us the scene like it is
without your backdrop ?
Dont take that for real, dont't wanna be offending, just joking :)
@Latexluv
yeah dat lightmeter is mean to us :)
and i think its right, if you look to the arms and hands for exmple.
basicly, this looks very good to me.
what happens if you delete your backdrop and rerender this ?
Thread: (OT) I'm Cancer Free!!!!! | Forum: Poser - OFFICIAL
@Acadia
well, beck from drinking my beers (got 4):
I held my promise to salute you with the first glass, 2 times.
meaning, from the bottom of my heart , just truly , simply wish you the best for your future.
i think i can say that because i have some "bitter" experience with cancer in my family.
About your ring, (that looks sooooo beautiful)
We (humans) need things to hold on, THAT ring may be your thing to hold on.
In general, one of our human strength is to never give up, because you ARE human, you have this strength inside you. (Just gets forgotten too many times)
Once i met a greece wise man, he told me that one task in our lives is to find the right keys.
Keys, yes there are so many, how to find them ?
For me one of these key's is music.
I am very much related to / concerned by music (srry not sure that this is expessed well, so
i say "music" or songs, or mp3's or you name it , means a lot for me.)
Thinking shortly about your positive message - and what it means for me - to be happy for YOU, 2 songs appears in my brain.
First one would be, "Ozzy Osbourne - Symptom of the Universe, and i MEAN the soft part it the end, not the hard-rock part at the beginning.
(just simply explains what happiness is for me, or what i'm dreaming off:)
Second one would be , Offer Nissim - Happy People.
Writing that, hearing "Derek Sherinian - Man with no Name" you can call me
crazy, poser addicted, or any thing that comes across your brain.
and yes, i love rock music, and yes im very much concerned to this,
and yes i better stop now.
