We couldn't find any threads matching the specified search criteria.
4 comments found!
RobynsVeil
"freckles overnight" :-)))))
No no, of course not, I do not hurry. The main thing - clarity of presentation.
I also admit, I have decided to little learn a Python, if saw a beautiful picture with freckles (and if it could not be obtained except through programming in Python), but not sure that you have so much patience. Therefore, I will be glad and simple solutions.
Thread: VSS Skin Test - Opinions | Forum: Poser - OFFICIAL
RobynsVeil
That's pretty old technology designed for much older versions of Poser. Poser Pro 2012 takes advantage of a much more sophisticated set of material room nodes.
Hm ok, I will take note.
It would be interesting to learn more about your method (which is to create freckles)
And actually, I would not want to go into programming scripts (I just want to freckles )).
I will be glad of any help.
bagginsbill ok, thanks, I`ll try it. The fact that I am looking for a complete replacement of the plug "Skin Realism Kit for V4" from daz, unfortunately it cannot work in PP2012.
Hi bagginsbill
Please, explain that for a beginner - how to make simple freckles and/or spots with VSS (In Poser Pro 2012)?
I used the manual as far as my understanding) Unfortunately I do not know very well English.
What I did: Load v4, load texture map on v4, load VSS_PR3_AO, load vssMainButtons.py and make synchronize. Now open material editor (with selected "VSS_Skin_Shader_PR3_1" in scene)
What should I do next? (If you can explain on the points)
