Subject: Seeking Opinions on Credo Lifeforms for Motion Files in Poser
adele opened this issue on Dec 13, 2002 ยท 5 posts
adele posted Fri, 13 December 2002 at 1:55 PM
Lifeforms is 40% off and I was thinking of getting it. I've downloaded the demo and will begin testing it, but was curious as to whether long time users found it to be worth the money for creating BVHs for animations or not. Thanks for the help. Adele
poserpro posted Fri, 13 December 2002 at 2:18 PM
the LFS CD has some, says, 67 motion capture files(*.lfa), you can load the mocap file and export as BVH, I did transfer all those mocap to bvh for poser to use, but I remember that I used a script to make them poser compatiable BVH. Not all their files are poser compatible as their joints are different to those of poser. other than this purpose, if you like to custom human motions, why not just do it in Poser ? which means you still need to keyframe poses in LF, and save as BVH ? No thank, I rather doing it directly in poser. here is one of the samples for your test, just c/p and save as *.bvh, import into poser and have fun. .......(BVH begins from the line below........use X Axis.... HIERARCHY ROOT Hips { OFFSET 0.000000 0.000000 0.000000 CHANNELS 6 Xposition Yposition Zposition Zrotation Xrotation Yrotation JOINT LeftHip { OFFSET 3.290000 0.000000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT LeftKnee { OFFSET 0.000000 -16.570000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT LeftAnkle { OFFSET 0.000000 -16.549999 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation End Site { OFFSET 0.000000 -3.294683 0.000000 } } } } JOINT RightHip { OFFSET -3.290000 0.000000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT RightKnee { OFFSET 0.000000 -16.510000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT RightAnkle { OFFSET 0.000000 -16.690002 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation End Site { OFFSET 0.000000 -3.474498 0.000000 } } } } JOINT Chest { OFFSET 0.000000 4.380000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT LeftCollar { OFFSET 0.980000 14.230000 1.640000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT LeftShoulder { OFFSET 4.750000 0.000000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT LeftElbow { OFFSET 0.000000 -11.770000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT LeftWrist { OFFSET 0.000000 -9.140000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation End Site { OFFSET 0.000000 -6.995400 0.000000 } } } } } JOINT RightCollar { OFFSET -0.980000 14.230000 1.640000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT RightShoulder { OFFSET -5.220000 0.000000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT RightElbow { OFFSET 0.000000 -12.330000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT RightWrist { OFFSET 0.000000 -9.110000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation End Site { OFFSET 0.000000 -6.995400 0.000000 } } } } } JOINT Neck { OFFSET 0.000000 16.350000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation JOINT Head { OFFSET 0.000000 4.580000 0.000000 CHANNELS 3 Zrotation Xrotation Yrotation End Site { OFFSET 0.000000 3.706518 0.000000 } } } } } MOTION Frames: 35 Frame Time: 0.033333 0.000000 37.646632 0.000000 -7.297819 -10.194951 -6.234011 4.303093 11.775607 -0.873195 -2.502585 22.766680 9.705265 0.000000 -15.003942 0.000000 -3.337394 -6.759135 -0.386396 2.833161 15.719117 -22.427912 0.000000 0.000000 0.000000 -0.884588 16.937616 -8.425966 -1.419928 0.006700 -1.105155 38.918594 -13.289311 19.417439 -30.803303 -35.051369 -37.284492 0.133168 -4.239598 0.004929 13.433952 -0.000924 -4.134950 -25.159084 21.690489 6.689357 -5.186034 -30.590206 -18.334257 -0.049079 -4.589606 -0.001967 -14.381688 48.090584 -0.003007 22.308949 -32.798443 30.229744 0.000000 37.542223 0.787402 -6.428456 -9.287499 -5.669110 3.735720 12.609652 -0.814198 -2.418377 22.290684 8.955107 0.000000 -15.645940 0.000000 -3.585472 -7.576364 -0.468908 3.137923 10.830307 -21.747108 0.000000 0.000000 0.000000 -1.846168 15.627611 -9.707828 -0.748647 0.005981 -4.127475 38.640095 -12.978561 19.795462 -31.154257 -36.669186 -36.812737 0.154169 -4.078578 0.005490 12.885861 -0.003584 -4.583066 -25.517172 21.736624 6.992307 -5.696871 -30.537550 -19.455931 -0.056090 -4.568639 -0.002237 -13.925587 48.761471 -0.001310 22.346533 -33.812698 31.084175 0.000000 37.455216 1.968504 -5.687727 -8.290502 -4.844195 3.648907 13.735344 -0.869569 -2.546601 21.237898 7.977845 0.000000 -16.168217 0.000000 -3.538101 -8.424283 -0.513263 4.066159 6.684656 -22.374832 0.000000 0.000000 0.000000 -2.708718 14.386012 -11.115054 0.259170 -0.001200 -6.718543 37.853199 -12.965855 20.044651 -29.406214 -37.971310 -34.223240 0.168180 -4.036636 0.005927 12.725775 -0.005087 -5.032952 -26.424959 21.276636 7.241269 -5.965377 -30.188881 -20.283346 -0.049079 -4.568639 -0.001958 -13.629543 49.231998 0.005813 22.124222 -34.937550 31.264282 0.000000 37.333405 2.755906 -4.869649 -7.310510 -3.973700 3.719042 15.044375 -0.964189 -3.015182 19.996187 6.964633 0.000000 -16.536180 0.000000 -3.682886 -9.249509 -0.585869 5.272733 3.675870 -22.903212 0.000000 -2.665090 0.000000 -3.529992 13.388289 -12.499359 2.089581 -0.004156 -8.289779 36.194508 -13.608555 20.087383 -27.115725 -38.850273 -31.278366 0.168180 -4.036636 0.005927 12.149206 -0.000045 -5.157531 -27.016336 20.811100 7.302482 -6.106944 -30.007669 -20.708298 -0.049079 -4.589606 -0.001967 -13.438439 49.299133 0.003665 21.024918 -36.239029 30.133627 0.000000 36.939704 3.937008 -3.776296 -6.458575 -2.954010 3.793607 16.368746 -1.068987 -3.787644 19.143942 5.693584 0.000000 -16.995131 0.000000 -4.103309 -9.736433 -0.693814 5.838338 2.035837 -23.128944 0.000000 -4.127513 0.000000 -4.458085 12.608755 -14.017559 4.308130 -0.000116 -8.757682 34.128429 -14.558525 19.829540 -25.469547 -39.290680 -29.241173 0.154167 -4.057607 0.005461 11.168973 -0.001516 -4.688651 -27.268150 20.748243 7.358380 -6.281929 -30.355282 -20.852274 -0.056090 -4.575628 -0.002241 -13.287724 48.988209 -0.000845 19.210625 -37.610245 27.944201 0.000000 36.720019 5.118110 -2.483804 -5.694170 -1.776663 3.668614 17.613894 -1.106761 -4.248528 18.830317 4.096494 0.000000 -17.448189 0.000000 -4.518355 -9.845021 -0.768743 5.437191 1.449860 -23.989353 0.000000 -4.204656 0.000000 -5.476530 11.774322 -15.516870 5.993040 -0.001204 -8.728054 32.513176 -15.010795 19.312370 -24.183273 -38.809826 -27.907490 0.147167 -4.134496 0.005312 10.518589 -0.004754 -3.638620 -27.962887 21.208216 7.755266 -6.673704 -31.280209 -21.137003 -0.077118 -4.547393 -0.003062 -13.137633 48.317432 0.000231 16.843571 -38.962780 24.972631 -0.393701 36.622143 6.692914 -1.493608 -4.996172 -0.534284 3.553271 18.605978 -1.135341 -4.076047 19.297142 2.475169 0.000000 -17.335449 0.000000 -4.572821 -9.248929 -0.735267 4.479602 1.329914 -24.986631 0.000000 -3.308710 0.000000 -5.765650 10.849226 -16.845407 6.385382 -0.004636 -8.504874 31.816275 -14.324091 18.497574 -22.799841 -37.248615 -26.769876 0.126165 -4.316483 0.004755 10.143102 -0.000429 -2.457727 -29.377583 21.708506 8.453607 -6.994151 -32.840630 -21.075829 -0.105156 -4.477503 -0.004111 -12.917223 47.297321 0.001682 14.109522 -40.159481 21.509499 -0.393701 36.553271 7.874016 -1.293994 -4.594110 0.375122 4.254617 19.019756 -1.387237 -4.113486 21.309187 1.393758 0.000000 -15.886299 0.000000 -3.664102 -7.659825 -0.483829 3.249050 1.297999 -25.106571 0.000000 -1.916559 0.000000 -4.716367 10.085643 -17.364433 5.568933 -0.001076 -7.947171 31.864664 -12.489908 17.148138 -21.746025 -35.160053 -26.137516 0.105160 -4.533414 0.004162 9.405183 -0.005965 -2.034794 -30.658741 21.409519 8.837263 -6.542464 -34.839401 -19.566069 -0.133189 -4.386642 -0.005101 -12.582122 45.947376 -0.002226 11.155855 -41.128300 17.798178 -0.393701 36.472796 9.448819 -1.333600 -4.657763 0.428795 5.012189 18.206024 -1.562231 -4.886185 25.896513 1.267725 0.000000 -11.827637 0.000000 -2.666541 -5.544212 -0.255216 2.293511 1.998145 -23.767227 0.000000 0.000000 0.000000 -2.854793 9.735902 -16.336777 3.903740 -0.000081 -6.988529 32.359367 -9.505050 14.965574 -21.408911 -33.176693 -26.308147 0.077133 -4.729375 0.003185 7.736444 -0.006161 -2.579596 -31.068066 19.827820 8.264471 -5.195520 -36.996571 -16.626606 -0.168217 -4.288521 -0.006298 -12.090167 44.285702 0.002486 8.153403 -41.759518 14.122301 -0.393701 36.316916 11.417323 -1.043459 -5.195930 -0.313415 5.398881 15.187621 -1.419618 -7.075131 34.115601 2.964931 0.000000 -4.015674 0.000000 -2.558721 -3.446306 -0.146981 1.922327 3.947741 -21.803474 0.000000 -1.958520 0.000000 -0.837103 10.329096 -14.076807 2.408213 -0.004697 -4.884500 32.234016 -6.379234 12.138877 -21.091799 -31.211388 -26.782024 0.035070 -4.925633 0.001508 5.327754 -0.001036 -3.935824 -30.739498 16.619068 6.473306 -2.720407 -39.137897 -12.166739 -0.196227 -4.176429 -0.007155 -11.360894 42.335106 0.004267 5.272048 -41.945011 10.764850 -0.393701 36.456128 12.598425 -0.545156 -6.163894 -1.927712 5.492980 10.065435 -0.955091 -11.629013 44.899036 9.288659 0.000000 5.107621 0.000000 -3.436603 -1.655543 -0.098657 2.266174 7.075480 -19.556791 0.000000 -4.379391 0.000000 1.111955 12.142914 -10.754861 1.944621 -0.002520 -1.385062 30.713640 -3.980414 9.235847 -20.514305 -28.968521 -27.557037 -0.007016 -5.156532 -0.000316 2.584200 -0.002678 -5.704137 -30.066294 11.946234 3.641393 0.569587 -41.151627 -6.828397 -0.224491 -4.057585 -0.014951 -10.355577 40.099464 -0.000686 2.703391 -41.591156 7.975982 -0.393701 36.473530 14.173229 -0.203151 -7.227382 -4.436072 6.047492 3.685594 -0.383963 -20.441946 55.041473 22.194628 0.000000 9.895552 0.000000 -4.498483 -0.167733 -0.006588 2.513247 10.465702 -16.705019 0.000000 -7.685375 0.000000 2.502187 14.624537 -6.284055 2.259666 0.005072 2.385567 28.730770 -1.448406 6.366946 -19.141924 -26.597494 -27.654436 -0.077196 -5.394731 -0.003637 0.833377 -0.006573 -6.676602 -30.218462 7.008140 0.544476 3.465296 -42.927650 -2.449703 -0.245471 -3.924526 -0.015409 -9.024576 37.604099 0.003107 0.582059 -40.569950 6.034163 -0.393701 36.444528 15.748032 -0.141073 -8.029860 -7.405313 7.179263 -3.025044 0.379094 -31.968691 61.011395 38.316452 0.000000 8.064095 0.000000 -5.305375 1.345562 0.125364 2.317007 12.800728 -13.517167 0.000000 -10.618726 0.000000 3.287058 16.984945 -0.887135 2.303355 0.004728 5.108461 27.660614 1.845754 3.544592 -16.544830 -24.668434 -25.342691 -0.168814 -5.618608 -0.015287 0.819405 -0.004305 -6.473309 -32.316212 2.673314 -2.488906 5.546850 -44.666531 0.410599 -0.273466 -3.784712 -0.016034 -7.472705 34.748680 -0.001350 -0.411691 -39.405769 4.973021 -0.393701 36.820826 16.929134 -0.171129 -8.546287 -10.274005 8.577953 -9.076118 1.357567 -39.079788 61.685360 49.018387 0.000000 2.896007 0.000000 -6.029138 3.169889 0.328127 1.875383 13.670615 -10.715731 0.000000 -12.608550 0.000000 3.366668 19.136616 5.346013 1.744421 0.006443 6.859342 28.005848 4.963137 1.106606 -13.855472 -23.645445 -21.365311 -0.239052 -5.723723 -0.018953 1.828184 -0.006320 -6.536885 -35.640072 -1.116622 -5.606778 7.340618 -46.488846 2.653193 -0.294426 -3.609710 -0.016276 -6.287901 33.174221 0.003724 -0.118559 -38.594578 3.620019 0.000000 36.762822 18.110237 -0.143052 -9.019736 -13.216992 9.582740 -13.204780 2.206874 -36.642792 57.223980 48.992981 0.000000 -1.867605 0.000000 -7.070205 5.197438 0.636983 1.454358 13.858528 -8.117553 0.000000 -14.079994 0.000000 2.849947 21.355000 13.258657 0.147022 0.002901 7.713755 30.175257 6.744242 -0.499534 -12.243743 -23.054955 -18.086395 -0.288568 -5.779575 -0.028573 1.633590 -0.001671 -7.973851 -37.689999 -4.047485 -8.063179 7.901907 -48.606247 3.226863 -0.329378 -3.385771 -0.016732 -5.721391 32.909309 0.004453 -0.231563 -38.378166 -0.154648 0.000000 37.057914 19.685040 -0.284031 -9.297782 -16.457966 9.939910 -14.938977 2.588056 -27.854586 47.873707 42.025730 0.000000 -4.897382 0.000000 -8.353324 7.006187 1.025183 1.207610 14.047298 -5.217587 0.000000 -15.476780 0.000000 2.007965 23.244757 22.478554 -2.214777 -0.001400 7.315411 33.798912 8.212936 -1.993501 -11.366882 -23.476458 -15.034642 -0.274521 -5.765609 -0.027830 -0.385691 0.004432 -9.635891 -37.915531 -5.070761 -8.704808 6.099530 -50.690651 0.830258 -0.343315 -3.175822 -0.016514 -5.545969 32.907368 0.003633 -2.085175 -38.510452 -7.044962 0.000000 37.260199 21.259844 -0.675108 -9.283550 -19.438631 9.519581 -14.778060 2.447529 -18.149776 35.229343 32.681683 0.000000 -7.348999 0.000000 -9.688479 8.568515 1.459597 1.118195 14.433619 -2.426075 0.000000 -16.904165 0.000000 1.256524 24.389515 30.757126 -4.240033 -0.001427 6.849183 37.528484 9.866746 -3.922635 -10.390273 -24.599701 -11.559895 -0.267493 -5.744656 -0.027427 -2.205069 0.001094 -10.248233 -39.036133 -4.778408 -8.642592 4.250899 -51.460644 -1.478097 -0.357303 -3.105901 -0.016684 -5.265810 33.335484 -0.001060 -4.131538 -38.799305 -13.415613 0.000000 37.334871 22.834645 -1.475845 -9.128366 -21.368340 9.203675 -13.627649 2.183281 -10.377591 22.596924 23.718426 0.000000 -10.274243 0.000000 -10.504879 10.348771 1.906022 0.999059 14.999151 -0.568922 0.000000 -18.369246 0.000000 1.056014 24.814606 36.558300 -5.018511 -0.002692 6.935070 40.258793 11.368829 -5.996937 -9.003610 -25.135538 -7.784783 -0.267493 -5.744656 -0.027427 -2.808776 0.003505 -10.144262 -41.436909 -4.229056 -8.758010 4.170165 -50.989658 -1.577703 -0.357315 -3.154844 -0.016837 -5.702855 34.225590 -0.001278 -3.779035 -39.218441 -17.062782 0.000000 36.859231 24.409449 -2.859635 -8.869751 -22.037949 10.095238 -12.569963 2.216640 -6.199859 13.718734 17.120468 0.000000 -12.685790 0.000000 -10.407764 12.317934 2.235173 0.630589 16.247860 0.284442 0.000000 -20.077950 0.000000 1.645338 24.559223 39.119972 -4.628111 -0.002664 7.866907 42.023560 12.747299 -8.183017 -7.426068 -24.769897 -3.814334 -0.288571 -5.786560 -0.028591 -2.717548 0.001262 -10.094917 -43.129509 -4.346923 -9.362842 5.773790 -50.068054 0.457323 -0.343329 -3.238746 -0.016703 -6.366806 35.308163 -0.000576 -1.651065 -39.750961 -17.731268 0.000000 36.562672 26.377954 -4.353796 -8.866294 -22.134212 11.267069 -11.847834 2.338706 -5.337304 10.094434 14.657241 0.000000 -13.199432 0.000000 -10.165619 13.898726 2.466028 -0.145751 19.254486 1.110161 0.000000 -22.405874 0.000000 2.666546 23.947954 40.050095 -4.599927 -0.000979 7.698888 43.847469 14.870477 -11.056769 -5.384730 -24.376009 1.486760 -0.309656 -5.793890 -0.029677 -2.318437 0.002132 -10.838504 -43.599010 -4.678442 -9.687757 7.114540 -49.454468 2.130625 -0.336338 -3.287687 -0.016649 -7.131507 36.317867 0.004079 0.849901 -40.346760 -17.208395 0.000000 36.029760 27.952755 -5.543761 -9.469358 -22.103710 11.625564 -11.115930 2.265274 -7.284721 10.419519 18.806463 0.000000 -10.984114 0.000000 -10.433489 14.858986 2.702819 -1.725949 24.214615 2.974661 0.000000 -25.013615 0.000000 3.299733 23.494514 40.449150 -5.114912 -0.003703 6.199099 45.760925 17.412823 -14.305070 -3.087340 -24.369480 7.514634 -0.309634 -5.786552 -0.029655 -1.293106 0.006106 -11.715527 -43.790352 -4.020760 -8.778575 6.529689 -49.867111 1.346799 -0.336331 -3.259722 -0.016567 -7.729398 37.009373 0.003468 2.861073 -40.999531 -16.537146 0.000000 35.885481 29.921260 -6.352786 -10.576493 -21.907440 11.313116 -10.286332 2.044792 -9.588431 12.890647 23.217966 0.000000 -7.145688 0.000000 -10.985872 15.097098 2.898973 -4.845247 30.546005 7.094979 0.000000 -26.046902 0.000000 2.576705 23.668201 38.920563 -3.779013 -0.000870 7.668620 45.743877 17.870729 -15.316278 -2.273686 -24.334719 9.548691 -0.309656 -5.793890 -0.029677 -0.147549 0.000215 -11.047443 -43.395313 -2.571882 -7.215679 5.139783 -51.040249 -0.407410 -0.343318 -3.189806 -0.016556 -6.695088 35.549381 0.000379 2.881904 -40.460133 -15.443658 0.000000 35.156085 31.889764 -6.677529 -11.879462 -21.354982 10.774355 -10.917773 2.063025 -11.473750 19.998575 24.002781 0.000000 -5.814927 0.000000 -11.633939 14.148580 2.872595 -8.802863 38.058380 12.346256 0.000000 -23.490929 0.000000 1.000608 24.095097 35.975529 -1.755434 -0.005056 10.388147 44.504398 16.981358 -14.554361 -2.517311 -24.367744 8.735229 -0.309661 -5.807861 -0.029715 1.024081 -0.005090 -9.186843 -42.227661 -0.439452 -5.194719 2.665655 -51.985519 -3.394561 -0.357307 -3.119885 -0.016728 -5.457472 32.840981 0.003510 3.080446 -39.500278 -13.203732 0.000000 35.207556 33.858269 -6.482827 -13.116855 -20.453257 9.899306 -12.693885 2.198697 -13.953576 30.038305 24.503206 0.000000 -8.933664 0.000000 -12.093381 11.890941 2.522729 -13.404533 46.066792 17.634489 0.000000 -16.027748 0.000000 -0.271015 24.137707 34.095646 -1.956512 -0.005236 8.507064 44.074028 17.168152 -14.027897 -2.201592 -24.784550 9.254646 -0.295613 -5.793896 -0.028966 2.707720 -0.003471 -8.739912 -40.637676 2.119259 -2.579956 -1.197791 -51.609764 -8.214562 -0.357315 -3.154844 -0.016837 -5.553624 35.016407 -0.001628 4.822529 -42.168468 -11.622078 0.000000 35.189421 35.433070 -6.147786 -13.808229 -19.089808 8.588328 -13.713825 2.044842 -15.283290 37.790401 24.490864 0.000000 -13.579437 0.000000 -11.658347 8.466080 1.733008 -17.727539 53.202030 20.688389 0.000000 -4.708413 0.000000 -0.613139 23.526600 33.237385 -4.415597 -0.003735 2.638909 44.685394 17.962736 -13.456490 -1.900889 -25.494902 9.933458 -0.267506 -5.779583 -0.027510 4.419789 -0.002728 -10.787985 -38.264828 4.145997 -0.168636 -4.008919 -49.579193 -12.063004 -0.336347 -3.329635 -0.016773 -6.742917 40.816872 -0.000225 7.886242 -46.539120 -10.437943 0.000000 35.293830 37.007874 -6.076539 -13.918643 -17.026567 6.745325 -12.355947 1.442771 -13.093926 39.482315 22.137543 0.000000 -15.963464 0.000000 -10.078618 4.689153 0.828344 -19.918818 58.289013 19.080748 0.000000 5.919704 0.000000 -0.625687 22.896645 30.400980 -5.975939 0.006563 -0.125728 44.388676 15.995737 -10.354875 -3.730247 -26.244728 5.715777 -0.239056 -5.737694 -0.018983 5.379292 -0.000114 -12.847396 -34.630806 5.537389 1.236155 -3.973983 -47.001656 -12.465622 -0.315405 -3.539578 -0.016743 -7.533003 43.969925 -0.000781 10.667410 -47.616367 -7.465373 0.000000 36.099366 38.188978 -6.267657 -13.644974 -14.327721 5.119652 -9.928894 0.887739 -9.114769 38.059788 18.261953 0.000000 -16.599480 0.000000 -7.869590 1.076793 0.144180 -18.364143 61.206993 11.512786 0.000000 11.335581 0.000000 -0.943551 22.629303 23.678818 -4.843642 -0.006350 3.626564 41.954636 10.187990 -4.448621 -8.035999 -26.797682 -3.906425 -0.196912 -5.653876 -0.016727 5.494158 -0.002656 -11.897662 -29.836140 7.333555 1.760458 -2.403191 -44.355202 -10.630622 -0.273445 -3.763510 -0.015982 -7.789027 42.438656 0.005564 12.398322 -44.289555 -1.596736 0.000000 36.546004 39.370079 -6.449200 -13.080542 -11.105394 3.809735 -7.329903 0.489552 -4.947229 35.188797 14.138165 0.000000 -15.999067 0.000000 -5.918629 -2.243611 -0.228084 -12.856894 62.018871 -0.312058 0.000000 10.169125 0.000000 -1.144278 22.286968 14.995399 -3.214262 0.000342 9.225133 39.119705 3.372636 1.155454 -12.762527 -26.627054 -13.791295 -0.147402 -5.548761 -0.007143 5.648813 -0.004341 -8.754767 -25.357323 9.526555 1.723489 -1.331871 -40.774853 -9.204278 -0.217493 -4.106516 -0.014796 -8.319522 40.427296 0.004683 14.056943 -40.572269 5.773992 0.000000 36.928837 40.551180 -6.545565 -12.515793 -7.509401 2.845626 -4.844021 0.239432 -1.362022 32.126980 10.033736 0.000000 -14.827836 0.000000 -4.787109 -4.968388 -0.418015 -4.838714 60.387775 -12.974096 0.000000 5.786632 0.000000 -0.925531 21.894979 7.579230 -2.368555 -0.004166 11.386991 37.150543 -2.360165 5.769149 -16.953686 -26.417765 -21.843063 -0.098251 -5.415689 -0.004647 6.084977 -0.004338 -6.938346 -22.247034 11.538305 1.796104 -0.924430 -37.406605 -8.620468 -0.154206 -4.358416 -0.005868 -8.787702 40.379646 0.001574 15.659291 -39.249718 11.388734 0.000000 37.166657 41.732282 -6.635411 -12.394497 -4.598076 2.394345 -2.194987 0.087858 0.905548 29.695711 6.885064 0.000000 -13.727769 0.000000 -4.418741 -6.843564 -0.523785 1.577467 56.345222 -21.645510 0.000000 1.986493 0.000000 -0.684540 21.977549 1.543692 -1.729523 -0.004853 11.927135 35.999786 -6.977478 9.375414 -21.221401 -27.378975 -28.311598 -0.007015 -5.128583 -0.000314 6.663780 -0.001023 -5.796474 -20.278152 13.298336 1.916502 -0.709674 -34.776573 -8.306265 -0.098147 -4.505459 -0.003861 -9.465919 41.307682 -0.001404 17.494942 -39.302017 15.995383 0.000000 37.693769 42.913387 -6.547536 -12.299637 -3.517963 2.308384 0.503351 -0.017137 1.350584 27.867203 5.894647 0.000000 -13.228028 0.000000 -4.589693 -8.513887 -0.678744 4.202876 50.719498 -24.708298 0.000000 0.000000 0.000000 -0.900022 21.738613 -2.398557 -1.328610 -0.003452 11.778893 35.648193 -10.475917 12.213186 -24.417347 -28.107098 -32.636242 0.056106 -4.869430 0.002386 7.853541 0.000339 -4.796720 -19.728300 15.133568 2.302743 -0.939701 -32.926994 -8.855832 -0.063383 -4.589602 -0.009540 -10.805484 42.608448 0.003423 19.667669 -38.458370 20.436546 0.000000 37.734373 44.488189 -6.797330 -12.097368 -3.617169 2.894543 3.228791 -0.158589 0.631339 26.458229 6.184936 0.000000 -13.164692 0.000000 -4.348907 -9.488722 -0.719293 4.644067 43.403347 -25.967068 0.000000 0.000000 0.000000 -0.829007 21.099257 -4.799062 -1.298829 -0.006323 10.443883 36.066334 -12.647361 14.493885 -26.393782 -28.867712 -35.046692 0.084143 -4.708410 0.003459 9.487106 -0.002054 -4.085386 -20.349569 17.017073 3.040122 -1.609280 -31.716545 -10.366735 -0.049081 -4.624550 -0.001982 -12.176944 44.016769 0.001455 21.267580 -36.920250 23.915953 0.000000 37.728572 45.669290 -7.286469 -11.855391 -4.393936 3.698095 6.036778 -0.384277 -0.363879 25.064775 7.279592 0.000000 -13.305261 0.000000 -3.755027 -9.859019 -0.633043 3.984422 37.386135 -25.720259 0.000000 0.000000 0.000000 -0.540640 20.264841 -6.166088 -1.486585 -0.001074 8.177200 36.955593 -13.715912 16.357149 -27.683107 -29.957174 -36.236496 0.105171 -4.603580 0.004227 11.249776 -0.003552 -3.676063 -21.664133 18.739605 4.027936 -2.534141 -31.020247 -12.478545 -0.035058 -4.624550 -0.001416 -13.364041 45.351376 -0.000658 22.203806 -35.119362 26.456724 0.000000 37.653165 46.850396 -7.718279 -11.490074 -5.386777 4.328671 8.670276 -0.644171 -1.322776 23.726004 8.669613 0.000000 -13.579437 0.000000 -3.193133 -9.266651 -0.518582 3.174777 31.396042 -24.468784 0.000000 -2.035446 0.000000 -0.266943 19.285564 -6.954193 -1.708445 -0.001696 5.276250 37.973980 -13.959121 17.792175 -28.678087 -31.447956 -36.718842 0.105159 -4.519437 0.004150 12.734329 -0.004775 -3.575331 -23.216473 20.176115 5.113816 -3.552494 -30.680168 -14.765834 -0.035058 -4.624550 -0.001416 -14.234825 46.496971 0.001965 22.566792 -33.507969 28.217024 0.000000 37.496553 48.031498 -7.814421 -10.957911 -6.147379 4.546753 10.678288 -0.832891 -2.024836 22.898809 9.727593 0.000000 -14.129443 0.000000 -3.074670 -7.390054 -0.394924 2.840781 22.957380 -23.146437 0.000000 0.000000 0.000000 -0.284192 18.179600 -7.574672 -1.769836 -0.004109 2.077595 38.755489 -13.682522 18.804024 -29.643602 -33.224678 -36.934441 0.126181 -4.407610 0.004856 13.586798 -0.002606 -3.747597 -24.532217 21.195744 6.092414 -4.499910 -30.576754 -16.857704 -0.035057 -4.603584 -0.001409 -14.634320 47.418797 0.007682 22.524603 -32.571716 29.408524
ockham posted Fri, 13 December 2002 at 2:40 PM
I bought the LifeForms program a while ago and found it wasn't worthwhile. It can do one or two things that Poser can't: for instance, LifeForms can force a character's feet to stick to the ground realistically, instead of "skating" as Poser usually does. But it requires a huge amount of labor to adapt a Poser model into LifeForms, and doesn't always work. On the other hand, I found Credo's pre-made BVH files to be worth the money. They import easily and cleanly into Poser.
My python page
My ShareCG freebies
lululee posted Fri, 13 December 2002 at 6:57 PM
Who is Credo? Are those files available here? Thanx in Advance.
ockham posted Fri, 13 December 2002 at 9:41 PM
The company website is Credo-Interactive.com. I don't think the files are available inside Renderosity, but Credo has various "packages" of BVH files for sale.
My python page
My ShareCG freebies
