RPlatz opened this issue on Dec 14, 2002 ยท 5 posts
RPlatz posted Sat, 14 December 2002 at 7:50 PM
I have Poser5 updated with SR2.
Any suggestions appreciated (other than give up this hobby before it drives me insane).
Little_Dragon posted Sat, 14 December 2002 at 8:01 PM
It might be a rendering problem, rather than a joint problem. Do you have polygon smoothing enabled in your Firefly render options?
RPlatz posted Sat, 14 December 2002 at 9:27 PM
These renders were done with the Poser4 renderer. If I import the mesh without the middle segment and then turn it into a figure it renders correctly. It only goes bad after I turn it into a figure making me suspect it's got something to do with the joints.
thip posted Sun, 15 December 2002 at 5:26 AM
Did you weld any seams, or do you have any body part "borders" running across the new geometry? If new geometry on top of existing geometry has any vertexes in common they sometimes "cross-weld" and create artifacts in rendering. If that's the problem, try moving or scaling the new geometry ever so slightly to make sure no vertexes are in exactly the same position.
RPlatz posted Sun, 15 December 2002 at 11:26 AM
You are correct sir! I had split the vertices on the new geometry to avoid a smoothing problem between the sides and top. I moved things a little like you suggested and the problems fixed. One more "work around" to add to my list of Poser quirks. Many thanks.
