ariaans opened this issue on Dec 16, 2002 ยท 2 posts
ariaans posted Mon, 16 December 2002 at 5:00 AM
I downloaded Java 1.4 to use Composer for the first time as I have Windows XP. I can read the geometry of an objectfile but cannot select anything. Am I doing something wrong or does Java 1.2 works better with Composer??? Pls help!
bloodsong posted Mon, 16 December 2002 at 7:32 AM
hmmm.... i seem to have 1.3.1, and that works. if the program is running, that should mean your jre is fine. after you load the geometry, i think you need to click that little key thing on the upper left to open a list of groups. did you do that? do you see them there? :/ (you do mean john wind's "compose" right? :) )
