Luthoricas opened this issue on Dec 16, 2002 ยท 6 posts
Luthoricas posted Mon, 16 December 2002 at 11:25 AM
Hmm. Is there something different about the format Poser ProPack uses for the png's ? Or is it my graphics program? I'm trying to edit the png's for a prop using Corel PhotoPaint7. Every time I do and go back into Poser, the png squinched up to the left about a third less wider than it used to be. ??
ockham posted Mon, 16 December 2002 at 11:56 AM
I'd suspect Corel. PaintShop7 doesn't have any trouble with PNGs.
Karma posted Mon, 16 December 2002 at 1:07 PM
png's for the poser library has to be the size 91x91, otherwise there will be problems. Check the size of your image
Luthoricas posted Mon, 16 December 2002 at 1:27 PM
Very interesting - before I open it the png is 91x91. Corel says it's still 91x91 after I've made changes. I save the image, close it, then re-open it and it's then 90 (wide) x 91. How wierd. Only with png's though.
bknoh posted Mon, 16 December 2002 at 6:50 PM
I can not get the png's I make in PSP work in Poser. I have to make pct's and convert them to rsr and then to png's. Diane
Little_Dragon posted Mon, 16 December 2002 at 8:43 PM
Make sure they're in 32-bit colour and have an alpha channel. If the thumbnails don't have an alpha channel, Poser assumes that the entire thumbnail is 100% transparent.
