seaturtle opened this issue on Dec 16, 2002 ยท 7 posts
seaturtle posted Mon, 16 December 2002 at 2:21 PM
Will Lightwave7 see the tex maps you created for your Poser model when imported from Pro pack? I tried to doo it quick but the textures did not load! Anyone know of any good tutorials
sturkwurk posted Mon, 16 December 2002 at 2:24 PM
Attached Link: Poser/Lightwave Tutorial
Curious Labs had a good tutorial on one of their lab reports. See link. The textures don't always seem to load for me and I end up tracking them down and applying them.I came, I rendered, I'm still broke.
Bobasaur posted Mon, 16 December 2002 at 8:12 PM
Most of the textures load for me but... 1). Poser uses multiply mode so it doesn't always look right in other apps. Use your surfaces panel in Lightwave and change the texture mode to additive. 2). Transmaps need to be inverted to work correctly in Lightwave. 3). Reflection maps are the ones I find that don't load. You could just reapply them in Lightwave or... You can change the surfaces completely in Lightwave as long as you don't rename (or remove) them. Therefore, you can eliminate the reflection maps completely and use a Lightwave-based reflective surface. It can sometimes be a real pain going through and adjusting the textures for Lightwave, but the end result is good!
kurokuma posted Tue, 17 December 2002 at 12:00 AM
I model all my stuff in Lightwave. I originally purchased Propack to help with a Lightwave project, and ended up converting my models to Poser format. It was too much a pain in the butt, trying to move poser stuff into Lightwave and have it work. I followed the tutorial, but it didn't work right for me. The textures were all wacked. I think the only testure that worked on figures was the main skin texture, but the eyes were Blind white orbs.
EricofSD posted Tue, 17 December 2002 at 1:08 AM
Oddly enough, look above, there's articles of TS and CL. Bummer that LW and CL aren't doing more with P5.
Lemurtek posted Tue, 17 December 2002 at 1:19 AM
kurokuma- I don't have Poser Pro pack, but if your using the millenium figures, you'll probably have to change the Eyeballs material/surface to be transparent. Vicky and the other millenium figures (well, I assume the others, I only have Vicky) have a transparent outer eyeball shell, to add more realistic highlights, but this transparency might not carry over. Something to try anyway. Regards- Lemurtek
Bobasaur posted Tue, 17 December 2002 at 8:30 PM
Fwiw, I'm working with basic Poser figures. I haven't tried the Mil. Figures yet. I suspect I'll buy my first one when Vicki 3 is released. We'll see how she works then, with P4 and PPP and LW 6.5 - on a Mac.
