Zenman53186 opened this issue on Dec 17, 2002 ยท 4 posts
Zenman53186 posted Tue, 17 December 2002 at 11:27 AM
Has anyone experimented with applying texture layers in the P5 material room? It seems as if it should be possible to combine transparency layers together. If possible, it would allow you to put skintight "clothing" (such as pantyhose, thighhighs, briefs, socks, etc.) onto any skin texture without needing to combine them in Photoshop or Paintshop (this assumes that the tranparency layers are designed to work with a particular skin texture) I have tried this using the "blending" math node, but have been defeated by the color of the node being included in the blend. So even though I have a psd layer with transparency, the "transparent" part gains the node color and shifts the color of the skin texture. Any thoughts?
