zippy opened this issue on Dec 20, 2002 ยท 3 posts
zippy posted Fri, 20 December 2002 at 7:10 AM
Very sorry again. I still haven't got this right. I meant to say that there is a texture material map called 'window catches' that you should all look out for. The main colour setting should be 'black' with NO texture file applied, and with invisibility turned OFF. This is worrying me a lot in that people can't get the window leading to show up on the Poser stable model. The kind compliments I keep getting just make me feel more embarrassed. I'm very sorry about this. Trouble is these models get so complicated and it is so easy to make mistakes. I have changed the material map so that it reads 'window leading' on future models. The reason why it was called 'window catches' was because cottage no 1 had window catches and I used the same texture map for the window leading. Now I'm no longer adding window catches as they are too fussy and complicated. I do hope people will continue to use my models but I fear they may still contain mistakes as this modelling gets very complicated at times. I don't want folk to be dissapointed.
jehllm posted Fri, 20 December 2002 at 7:36 AM
your stable model is amazingly good, and I hadn't even noticed the issues you raised. your models are greatly appreciated!
SAMS3D posted Fri, 20 December 2002 at 8:15 AM
zippy you are coming along nicely, just remember to take your time and you will always end up with the beatiful models you have availble for others now. Sharen
