dglidden opened this issue on Dec 20, 2002 ยท 4 posts
dglidden posted Fri, 20 December 2002 at 4:26 PM
Is anyone else having problems doing some of the full body morph injections in Poser5? I'm being prompted to locate files for the morphs even though the path is correct for the injection files i.e: "libraries:!DAZ:Victoria 3:Body:Deltas:filename.pz2" Is anyone also having problems with the supermodel full body morph not working at all?? It loads but when you set it to 1 nothing happens in either Poser4 or Poser5.
dglidden posted Fri, 20 December 2002 at 4:44 PM
Ok I found my problem with the full body injections for p5, but the supermodel still isn't working.
rbtwhiz posted Fri, 20 December 2002 at 4:56 PM
"SuperModel" the pose, made it in the installer by mistake. If you look further up in the same directory you'll see a pose titled "Buxom". It is the exact same morph; "SuperModel" was the working name for that particular morph while it was being built. One too many nights that ended around 4am I suppose ;) -Rob Whisenant Content Production Coordinator DAZ Productions, Inc.
dglidden posted Fri, 20 December 2002 at 5:04 PM
Thanks Rob
