Anthony Appleyard opened this issue on Apr 21, 2000 ยท 7 posts
Anthony Appleyard posted Fri, 21 April 2000 at 4:51 AM
I have accessed the Wishing Well several times from a LAN line st work, the first time the place showed to submit a vote, which I did; after that the voting place did not appear. And only one of the comments ever showed :: one by Devlin.
Just now I logged into it on my laptop at home on a dialup line. The first time it showed a place to put a vote in, and it showed all the comments. Then I looked at it again, and there was no place to vote, and, more seriously, it only showed one comment (one by Devlin). I suspect that the Wishing Well contains some software (in Java?) to stop people from voting twice, and that that software has a bad bug.
Anthony Appleyard posted Fri, 21 April 2000 at 4:54 AM
The one comment that showed was as below. I seem to remember that it was the first comment, on the one accasion that all the comments showed.
Reader Submitted Opinions: By: Devlin on 2000-04-17 Collision detection, and morphs so that, say, when an arm hits a lig, they both 'squash'. I really hate it when arms just pass through each other. Also better shaping on the neck, 'cause when you turn it it goes all deformed.
Anthony Appleyard posted Fri, 21 April 2000 at 6:57 AM
If I start Renderosity on its front page and right click the Wishing Well and choose "open on new window", up comes not the Wishing Well but the front page again. If I right click Wishing Well on that and choose "open on new window", then the Wishing Well does come up - with only Devlin's one comment showing.
BAM posted Fri, 21 April 2000 at 9:04 AM
I have had no problem accessing the Wishing well. T1 connection, Gateway PIII 96MB RAM W98
BAM posted Fri, 21 April 2000 at 9:58 AM
Only one wish per person? I submitted 3 will it only take the first one?
fur posted Fri, 21 April 2000 at 10:01 AM
if you are posting it as an answer to the poll, it will only take one. if you are adding an opinion, you can add as many as you like. i don't know which method you were using to answer.
fur posted Fri, 21 April 2000 at 10:05 AM
ok, there was a bug that kept the opinions from showing
