Subject: Creating Furniture and Adding Morphs
motorhappy opened this issue on Dec 21, 2002 ยท 5 posts
motorhappy posted Sat, 21 December 2002 at 2:36 AM
Would it be possible to create something like a locker in Poser using the primitives and make a door on it that can be opened and closed by a Morph dial? Are there any other programs that may need to be incorporated?
Evanara posted Sat, 21 December 2002 at 6:30 AM
Hi ! I haven't tried building a prop from within Poser itself but I used 3DS MAX to build props , export them to OBJ format and then used UVMapper and PHIBuilder to make it posable in Poser (this result in a Character (CR2) file rather than a Prop (pp2) file) . Works well for rotating parts , I still have to figure out how to do sliding parts (other than parenting to the main part of the prop). I guess you could do the same from Poser by exporting the object to an OBJ file and going through UVMapper and PHIbuilder . There should be tutorials for Prop/figure building here and there is (or was) a good one at Poserworld . Both UVM and PHI are available from the Freestuff section. Take care.
motorhappy posted Sat, 21 December 2002 at 11:30 AM
Thanks for the info. I'm very new to this program and pleased to see how helpful people on Renderosity have been.
maclean posted Sat, 21 December 2002 at 2:25 PM
motorhappy, Yes, what you're asking is possible, but it would be easier if the props were combined to make a figure, rather than a prop. It's not THAT difficult to do. I'll try to run through the basic steps of making a simple box figure with lid. 1. Open the poser box prop and scale it to the length of your box, using the X and Y scale dials. Reduce the Zscale (thickness or depth) to about 5%. Do this with 4 boxes for front, back, top and bottom. 2. Do the same again with another 2 boxes for the sides. 3. Position all the boxes so they form a cube, and if possible, make a note of the box numbers and where they are. This will help you later to know which ones are which. 4. Go to Menu/File/Export/Wavefront OBJ and in the 1st dialog box, click OK for single frame, then in the 2nd (the hierarchy box), make sure your 6 boxes are all checked. Hit OK, type in a name for your obj, then in the last dialog box, UNCHECK EVERYTHING EXCEPT THE 1ST OPTION (include body part names in polygon groups). You now have your box obj saved. This file needs to be stored somewhere in Runtime/Geometries/Whatever folder. Poser now needs a PHI file to create a figure. If you don't have PHI Builder (free app in Utilities), you can easily make a PHI file in notepad. This is what you type. objFile :Runtime:Geometries:YourFolder:YourFilename.obj 1 box_1 xyz 1 box_2 xyz 1 box_3 xyz 1 box_4 xyz 1 box_5 xyz 1 box_6 xyz Save that with a name and the extension .PHI. like box.PHI, then open poser and go to Menu/File/Convert Hier File. Poser will ask you to name the new figure and a new entry will be added to New Figures in the library. NOTHING WILL APPEAR IN THE DOCUMENT WINDOW. Don't panic! Double-click on the new entry and it will open. You should now have a box with a BODY and 6 body parts (boxes 1 - 6). All you need to do now is select each body part and turn off the 'bend' option. You can also rename them to front, back, lid, sides, etc. To make the lid posable. 1. Select the 'lid' body part and go to Menu/Window/Joint Editor. 2. You'll see 2 crosses on the lid, a green and a red one. Use the different cameras (especially Top) to get the correct view, and either use the mouse to move the center of the green cross (the cursor turns to a circle), or type the values into the Joint Editor. What you want to do is move the green cross in line with the back of the lid. Then use the Xrotate dial to raise the lid. You may have to mess around to get it perfect, but it's not difficult. Once you've done all that, resave your figure (in Characters, remember) with it's new joints and it's done. You can also turn it sideways to have an upright box with opening door. The box will accept simple textures because the poser boxes are already texture-mapped, so you don't need to bother mapping it. If you have uv mapper (free - www.uvmapper.com), you can make more complex maps, or even assign different materials to each side of the box. Whew! OK. Those are the basic steps. It sounds a lot written out like this, but it's actually very easy once you've done it a few times. And from there on, you can get into more complicated things. Any poser props can be combined to make interesting things if you take the time to learn the basic steps. Also, try www.anim8or.com for a great, free 3d model maker. I use it almost every day for making morphs for furniture and things. It's very useful. Steve Shanks had a good tutorial on morph-making in anim8or. Sorry for the long rant. I keep meaning to put all this into a simple tutorila, but I never have time. Evanara, Sliding parts - Easy. Just use the trans dials (usually Xtrans) to slide the door or whatever back and forth. mac PS If you need help, just shout!
Evanara posted Sun, 22 December 2002 at 12:02 AM
Thanks Maclean . It was so obvious I didn't even think of using the trans dial :) . Nice tutorial too. Evanara
