DocMatter opened this issue on Dec 27, 2002 ยท 3 posts
DocMatter posted Fri, 27 December 2002 at 8:37 AM
I tried making an animation with the P5 dynamic hair and it came out looking like a bunch of angry bees...hairs constantly moving all over the place. I had "do collisions" checked for each hair section plus had "collisions on" and had the appropriate parts of Stephanie "collison enabled". Its probably from the hairs colliding aganist each other. So how do I keep this from happening but also keep the hair from passing through Steph's body? P.S. I'd attach the video, but its too large...sorry.
Velen posted Fri, 27 December 2002 at 9:16 AM
at this time P5's hair simulation dose not work properly. it is only useable to add reaizum for a still shot, sence as you have seen the hair dosent drape it just wipps around. so use the styaling tool to set up hair the way you want it. and go from there. hope this helps Vel
HandspanStudios posted Sat, 28 December 2002 at 1:23 AM
Maybe try playing with the 'damping' 'spring strength' and 'gravity' factors under 'dynamics controls'. Increasing those first two should make poser think the hair is heavyer and maybe it'll wip around less? Not that I've tried it ;-) myself, that's the theory though.
"Your work is to keep cranking the flywheel that turns the gears
that spin the belt in the engine of belief that keeps you and your
desk in midair."
Annie Dillard
