kelley opened this issue on Dec 31, 2002 ยท 8 posts
kelley posted Tue, 31 December 2002 at 8:07 PM
EtchASketch posted Tue, 31 December 2002 at 10:57 PM
I am a very unique person... Just like everyone else
EtchASketch posted Wed, 01 January 2003 at 12:16 PM
Change to Spiral;
Turns=5
Length = 0
Dist axis =3.5
Scale 100
Scale 0
Then Create multiple sections = 45
Edit the handles to create folds.
It can get a bit troubling selecting handles and sections. Carraras modeler is a bit limited with inability to lock items and change bezier handle colors etc.
bluetone posted Wed, 01 January 2003 at 1:28 PM
Try setting the modeler to "Only see selected" under the cross-section menu. Then you can chose "next" or "previous" to change which cross-section your working on. This makes it simpler to see what your editing, and wont effec tthe other cross-sections. By-the-by... great modeling! I want to put in on my back and go out into the woods. I'd like to see it after you texture it.
kelley posted Wed, 01 January 2003 at 2:42 PM
Thanks for the info. I'll try it out tonight.
EtchASketch posted Wed, 01 January 2003 at 6:44 PM
Would make a nice Cinnamon roll on a coffee table with the correct proportions. (A hint for those wanting to make more simple things for scene elements) Too bad shapes are apparently static in 2D space. To be able to move the vertices off their singular planes would be desireable. (Take the abrupt end of the roll for example. To be able to tug some of those vertices out would be nice.) good luck Kelly
kelley posted Thu, 02 January 2003 at 10:19 PM
The image above is the Bedroll slung under a Backpack. It's pretty close to what I had in mind. Needs a work on the cloth color and a good bump map under the patches. Backpack is an initial rough-cut only. Much more work needed here.
Nicholas86 posted Sat, 04 January 2003 at 9:27 AM
nice improv! looks good kelley!
