MRrobotto opened this issue on Jan 01, 2003 ยท 6 posts
MRrobotto posted Wed, 01 January 2003 at 12:17 PM
This could also apply to older versions of Victoria, and it's something thats been bugging me. When I try and make my own faces I can't seem to get rid of her rather manly, square jawline. What morphs should I be using to obtain a softer, more feminine effect? Try as I might, I can't seem to get rid of that Dan Dare profile. Any tips for a novice face maker?
SamTherapy posted Wed, 01 January 2003 at 12:29 PM
Try dialing in a heart shaped face first. That will give you a narrower jaw compared to the rest of the head.
Jon posted Wed, 01 January 2003 at 1:33 PM
In the Features face morphs you'll find the square face which can be set to a negative value and also various jaw morphs which make it smaller, fuller, younger, etc. The "MandibleSml" morph should also do the trick. Don't forget to play around with morphs and use them in the negative as well for more variety.
PheonixRising posted Wed, 01 January 2003 at 2:46 PM
Also use a tiny bit of Faerie and dial male head backwards a bit. Then dial another ethnic morph forward a bit like "Young" or "Celtic"
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
MRrobotto posted Wed, 01 January 2003 at 4:14 PM
Thanks for the advice, I'll give it a go. Basically I want to make a face that's more Maiko than Michael. I'm wary of using too much "head Japanese" because the face starts to resemble a charicature.
PheonixRising posted Wed, 01 January 2003 at 4:30 PM
Turning some morphs backwards helps.
-Anton, creator of
since 3-13-07
