Subject: Newbie question..How do you morph a object....
Dermagrfx opened this issue on Jan 03, 2003 ยท 10 posts
Dermagrfx posted Fri, 03 January 2003 at 10:58 AM
How do you select a object and how do you morph the oject selected thanks for any help on this subject.....Russell
PheonixRising posted Fri, 03 January 2003 at 12:57 PM
You can select from the bottom of the document window. Use magnets to make morphs. They are attraction tools that can pull, push, roatate and scale mesh alone or all at once.
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
PheonixRising posted Fri, 03 January 2003 at 12:59 PM
There are three parts to a magnet. Make the zone partially visible. The zone defines what area you want to affect.
PheonixRising posted Fri, 03 January 2003 at 1:01 PM
Notice what is going on. BASE is where the ceter of the action is starting from ZONE is what is being affected MAG is what does the deformation
PheonixRising posted Fri, 03 January 2003 at 1:03 PM
-Lastly you spawn a morph and delete the magnet. -When you spawn a morph target you get a dial for it with whatever name you want. -You can set different morphs and spawn one from the dials too. Goodluck, Anton Daz3d
dialyn posted Fri, 03 January 2003 at 1:03 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=895452
My apologies for ending up in the middle of this mini-tutorial. If you happen to need another tutorial (and you probably won't...this looks wonderful), Dr. Geep also gave a lesson on the same subject. FYI only. Now I am back to paying attention to what is being posted here. I've never been good with magnets myself. :)
PheonixRising posted Fri, 03 January 2003 at 1:05 PM
forgive my sloppy typing
dialyn posted Fri, 03 January 2003 at 1:08 PM
Anton...thank you so much for this. Typing skills aren't as important as the value of the information you share. Really appreciate it...even though I wasn't the one that asked in the first place (it's a good question, though).
tasquah posted Fri, 03 January 2003 at 1:50 PM
bookmarked
jade_nyc posted Fri, 03 January 2003 at 2:01 PM
Attached Link: Morphworld 3
You should get Trav's Targo-Magnet from Morphworld in the files section - www.morphworld30.com - it makes using magnets a lot easier with its crosshairs. And while you're there - he's got a series of magnet tuts in his tutorial section. They really helped a lot when I started playing with them.
