SRAM opened this issue on Jan 03, 2003 ยท 6 posts
SRAM posted Fri, 03 January 2003 at 3:38 PM
how do i get them?
Work It Harder. Make It Better. Do It Faster, Makes Us stronger.
More than ever, hour after hour. Our work is never over. - Daft
Punk
SamTherapy posted Fri, 03 January 2003 at 4:00 PM
Lashes are pretty much built onto all Poser models, but eyebrows differ between some. In order to get realistic looking lashes, you must apply a transparency map to the eyelash area. This is like a texture, but acts to make certain areas opaque on an otherwise transparent object. On a transmap, black is completely see through, white is completely opaque. Greys are different degrees of transparency. The default Poser figures have no separate eyebrows, and they have to be painted onto the heads. On the DAZ figures (Mike, Victoria and Stephanie - plus the Millennium kids) the figures have a separate eyebrow material which can be altered by using a combination of textures and transparency maps.
SRAM posted Fri, 03 January 2003 at 4:39 PM
ok, thanks, now, im not sure about these transparent maps and object, what not. is there a tut, or can u or some one else please help me with this subject? like, how can i change them, or can u? thanks again
Punk
SamTherapy posted Fri, 03 January 2003 at 5:53 PM
Attached Link: http://www.renderosity.com/tut.ez?Sectionid=12356
Search through here and look in the Help menus of Poser.Coppula eam se non posit acceptera jocularum.
PabloS posted Sat, 04 January 2003 at 3:38 AM
antevark posted Sat, 04 January 2003 at 5:06 PM
tell me if u figure out how to make the eyebrows look good, thats the main thing i don't like in posette (another is the sharp edge in inner edge of the eyebrows, and the top of the lips are too straight).
