Subject: jpeg to .bum
Alastor_God opened this issue on Jan 05, 2003 ยท 7 posts
Alastor_God posted Sun, 05 January 2003 at 4:13 PM
Do you guys know how to convert .jpeg to .bum? I seem to be having trouble getting V3 to look proper.
sirkrite posted Sun, 05 January 2003 at 4:21 PM
In P4 in the matrial room you have to goto where it says bumps and re-open the .jpeg and Poser 4 will then ask if you want to convert it. Just say yes! :) Click open, then locate the Bump.jpeg for what you need.
tasquah posted Sun, 05 January 2003 at 4:32 PM
Alaster : Are you useing Poser 4.0 or Pro Pac or P5 ? its all different for bump maps .
Alastor_God posted Sun, 05 January 2003 at 4:45 PM
im using P4 i got V3 and it says that i have to convert the .jpeg texture files into .bum to be able to use/customize here.
Crescent posted Sun, 05 January 2003 at 4:51 PM
Just go to Render: Materials and select the .jpg file for the bump section. Poser will offer to convert it to .bmp. (P4 doesn't have a Material Room as such.)
PheonixRising posted Sun, 05 January 2003 at 6:56 PM
If you save the image as a .BMP you can just right click and rename the extension to .BUM But that only works for .BMP (bitmap) file Anton
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
rogergordian posted Mon, 06 January 2003 at 6:30 AM
1.) Before you use Vicky 3, run Poser, and load a prop. I use the ball. 2.) Go into Render, Materials, and Bump Maps. Find the bump map and load it. 3.) Say Yes when Poser asks if you want to convert the bump map. When Poser is done, select the next bump map to be converted, till you're done. 4.) When you're all done, click OK. Then get rid of the prop. 5.) You're ready now.
