Forum: Vue
Subject: Comments invited
jwhitham opened this issue on Jan 05, 2003 ยท 8 posts
jwhitham posted Sun, 05 January 2003 at 5:27 PM
Hi, this started out as my first go at playing with volumetric lights, but I like the effect so much I started thinking about submitting to e-on's gallery. At least if I could find Posette something decent to wear, and stop her hair sticking out at silly angles! Anybody think it might make the grade?
John
jaywat posted Sun, 05 January 2003 at 6:36 PM
Attached Link: http://www.wibwobweb.com
Nice image. Personally I like the way her hair flows. It looks like it's moving in the wind. Perhaps you could make further suggestion of that by leaning those grasses on the right hand side towards the right as well. I also like the simplicity of the dress. It doesn't detract from the rest of the image. Perhaps consider a subtle pastel red or something if you are looking to bring her out more. Other than that, if you were looking for suggestions on how to enhance the image further, I would think about adding more foreground vegetation so that it doesn't look quite so flat. And perhaps reducing the scale of the texture/bumps on the foreground rock. The texture looks fine for sandstone type rocks, but the texturing on the landscape in the background suggests to me that the local rock here is a more sedimentary and finely textured rock ;) My tuppence worth. HIH. -- Jason
ChuckEvans posted Sun, 05 January 2003 at 9:15 PM
I think it definitely needs more veggies...trees and underbrush. It seems unlikely that those (two trees) should be the only trees around. The caslte looks like walls surrounding a tower. If you don't have anything else to add to it, then I'd let it "peek" through the trees (and such) that I suggested added. Of course, that's just an artistic opinion. You may have a different image in your mind.
YL posted Mon, 06 January 2003 at 5:36 AM
Nice depth in this picture. I think you should improve the light ;the volumetric beam looks nice, but there are probably too much ambient in the atmosphere. You could try to apply Sascha's (ngalai) light tutorial (see above link) to your outdoor scene. That's my 2 cent, ;=) Yves
gebe posted Mon, 06 January 2003 at 1:29 PM
I like the hair and the lighting very much. The roc in the foreground looks a bit wrong, so does the texture of the dress, they need to be improved. I'm sure with little work this image will lock great. :-)Guitta
gebe posted Mon, 06 January 2003 at 1:30 PM
Oh I forgot. The right arm of the girl is not right.
jwhitham posted Tue, 07 January 2003 at 1:19 AM
Thanks for the comments. I wouldn't usually explain what I'm trying to achieve - if I did I'd have failed, yes? - but seeing as I'm asking for advice here... The (accidentally arrived at) background made me think of vague childhood memories of places. So I wanted to achieve a contrast between the unrealistic past backdrop and a realistic, slightly threatening, foreground future, with the girl standing on the boundary between the two. Sorry if that sounds a bit pretentious:) Anyway, on my home monitor it looked great. Tried it on a TFT panel at work and the foreground looks horrendous, especially that damn rock. Must turn up the brightness on my monitor! There's certainly way to much ambient light too. I'm working on it. John
YL posted Tue, 07 January 2003 at 5:35 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=945013
Did you checked the gamma setting for your monitor ? I had a problem two month ago when I discovered I was working with a 2.4 gamma (standard PC) as the standard for graphic seems to be gamma 1.8 (standard MAC). Follow above link to have more informations on monitor calibration (brightness, contrast) ;=) Yves
