Subject: Dynamic Clothing - What does it do?
Dragontales opened this issue on Jan 06, 2003 ยท 6 posts
Dragontales posted Mon, 06 January 2003 at 4:57 PM
Hello, I dont' have poser 5 yet. I'm one of the skeptics that refuses to buy it because of all the bad publicity it had about bugs and such. Having said that, I just came across an item in the marketplace that said it was dynamic clothing. I'd love to know more about this. What does it do. Is all clothing in P5 dynamic or can it be made to be dynamic, etc? If you have some great images that utilized this feature, I'd love to see those as well. Thanks for you help. Dragontales
EsnRedshirt posted Mon, 06 January 2003 at 5:36 PM
Don't have any images handy, but Dynamic Clothing drapes itself like real cloth on your figure, resulting in much more realistic still images. Even better, for animations, it will calculate out the physics and move like real cloth. It's one of the great new features in Poser 5, along with the Materials Room for special lighting and textures, the figure Setup Room which lets you set up new Poser figures graphically instead of having to manually do it by text, and the Hair room which generates strand-based hair. As is obvious, I'm a bit of a Poser 5 fan, I haven't had any problems on my computer.
PhilC posted Mon, 06 January 2003 at 5:54 PM
Attached Link: http://www.philc.net/tutorialsIndex.htm
![haremComposition1.jpg](http://www.philc.net/Poser5/haremComposition1.jpg)
Even though you do not have it yet you may like to look through a couple of Poser 5 tutorials. They will give you an idea of what you are missing.
Dragontales posted Mon, 06 January 2003 at 9:13 PM
Ok, it's kinda like the Clothreyes plugin for max, but one question I have is thus. If I take Vicky, and use custom morhps on her, then take her and the clothing item into "The tailor", so that it roughly fits her, will the dynamic cloth then be able to take it and perfectly fit it to her? For instance, a pair of stockings, for simplicity. One problem I've had is some parts of vicky poke through the stocking object, and some parts of the stocking object are very visibly a distance away from the leg that it doesn't look right. Will this feature be able to take it and make it fit right to her?
jjsemp posted Mon, 06 January 2003 at 11:48 PM
It does this... And by the way, don't listen to all the bad P.R. Poser 5 is well worth it. -jjsemp
jjsemp posted Mon, 06 January 2003 at 11:50 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1037729
Go to the above link to see a few more examples...
