hawktoey opened this issue on Jan 07, 2003 ยท 9 posts
hawktoey posted Tue, 07 January 2003 at 11:22 AM
Okay, don't know if this has been dicussed here or not. I have looked and cannot see any. So, If you are going to create a new V3 character for distribution. And only use a few dials. You can make a pose pz2 file to inject those dials for her. When you make your character mark which dials you used. Save when done as a pose file pz2. Now open a text editor and create an injection pose for her. Here is a sample of the way the file should look with just one dial added... { version { number 4.01 } readScript ":Runtime:Libraries:!DAZ:Victoria 3:[finish path to injector here]" figure { defaultPick BODY } readScript ":Runtime:Libraries:!DAZ:Victoria 3:[finish path to injector here]" } Now just copy and paste as many sections that are needed and edit the sections to point to the injectors/dials you have used. Save, into the pose directory where your character Mat/Mor pose file is, as a new pose file like "(character name)InjPose.pz2. My opinion is that DAZ created V3 so we could have a denser mesh, and the injecting of dials helps do that. The problem is that some are creating new characters for her then telling people to load all morphs. I know two people that have systems that can't do this (load V3 with all morphs), and I am sure that there are more. Your readme should tell the person using the character to click on the inj pose then the Mat/Mor pose. I hope this is useful to those that create new characters for V3. And I hope this is all good. I have tried it and it works for me.
Spit posted Tue, 07 January 2003 at 2:49 PM
Thank you!!
PabloS posted Tue, 07 January 2003 at 7:08 PM
"Your readme should tell the person using the character to click on the inj pose then the Mat/Mor pose." Could you incorporate the MAT/MOR following the readscripts that inject the morph(s) and have a single pose file?
tasquah posted Wed, 08 January 2003 at 12:57 AM
hawktoey posted Wed, 08 January 2003 at 6:15 AM
PabloS, I have tried to include the Mat/Mor with an Inj pose and have not had any luck yet. I am still trying to figure what I am missing to make it work. In theory one would think that it would...
Phantast posted Wed, 08 January 2003 at 6:32 AM
Is the path to the injectors critical? I was not happy to have the top of my pose folder dumped on with a lot of !V3 folders, and renamed them all to put them at the bottom, and will shortly shunt the lot of them top the cameras section to make room. I imagine others will be doing the same thing.
VI_Knight posted Wed, 08 January 2003 at 11:01 AM
hawktoey posted Wed, 08 January 2003 at 2:41 PM
Phantast, the actual path to the injectors is not to the pose folder. So what you did is fine. If you look at the sample file above the actual injectors/dials are in the... /Runtime/Libraries/!DAZ/Victoria/* directories.
unzipped posted Fri, 22 April 2005 at 8:35 PM
bookmark
