Forum: Poser Technical
Subject: how do I set vicky hair to mil girl ?
digitalman opened this issue on Jan 07, 2003 ยท 5 posts
digitalman posted Tue, 07 January 2003 at 7:34 PM
evrytime I move the vicky hair to fit into mil girl after I move the body, the hair won't fit again. I know there is some way to set the parents from the menu, but when I click it from menu it only show the option to let you set the camera part instead of figure part.How can I switch ?
SAMS3D posted Wed, 08 January 2003 at 4:08 AM
Make sure that hair object is selected before you parent it. Sharen
digitalman posted Wed, 08 January 2003 at 6:45 AM
I did select the hair object, but when i try to parent it, the menu come out anf let me choose only cameras
TrekkieGrrrl posted Mon, 13 January 2003 at 6:14 AM
There are 2 ways of parenting things like hair. I've expirienced the same as you, no "figure 1" to use as a parent. Now I'm not on my Poser PC so I can't tell you which of the following 2 ways actually work G But choose the opposite of the one you've been using :o) 1.: Double-click on the hair and from that box that pops up, choose "set parent" 2.: Select the hair and go to the (object?) menu and choose Set Parent. One of them works, the other doesn't. Have no idea of why.
iamonk posted Mon, 13 January 2003 at 8:07 PM
I have had some luck using MAT pose edit to create a pose for hair that changes the ytrans and ztrans to suit the MilGirl.
