Selket opened this issue on Jan 09, 2003 ยท 9 posts
Selket posted Thu, 09 January 2003 at 9:49 AM
PhilC posted Thu, 09 January 2003 at 12:10 PM
Look at the center points for the hip and thighs and ensure that the centers AND end points match those of the Vicki figure. I'm guessing that you have matched the centers but not the end points.
How did you bone the figure? Did you edit an existing CR2, use the setup room or write a PHI file?
Selket posted Thu, 09 January 2003 at 1:13 PM
i edited the existing CR2. any idea what maybe causing it to go gibbled? thanks phil
PhilC posted Thu, 09 January 2003 at 1:25 PM
Existing CR2 ... OK. There may be preset bends still in it. Try this:-
That should fix it.
Selket posted Thu, 09 January 2003 at 1:47 PM
ok I'll try it.. oh i have a question to ask for victoria 2 do u cut sections for the right and left buttocks, right and left thigh? or leave the buttocks out? thanks phil
Selket posted Thu, 09 January 2003 at 2:05 PM
Valandar posted Thu, 09 January 2003 at 2:16 PM
If it's for Vicky, there's also a right and left Buttock... rButtock/lButtock...
Remember, kids! Napalm is Nature's Toothpaste!
PhilC posted Thu, 09 January 2003 at 2:18 PM
Nearly there :)
Yes because the hip goes down to the knees go with Thighs and exclude buttock. Now you are down to adjusting the joint parameters. Start by having Vicki in the zero pose then work on one parameter at a time. You'll most likely have to increase the size of all the spherical fall off zones to take in the extra size of the dress. Also check the Vicki soften hip morph. The default setting is "1" you may need to zero it.
Selket posted Thu, 09 January 2003 at 2:51 PM
thanks phil i'll try those.
