Alastor_God opened this issue on Jan 10, 2003 ยท 5 posts
Alastor_God posted Fri, 10 January 2003 at 3:29 PM
Crescent posted Fri, 10 January 2003 at 3:41 PM
What MAT file did you use? Are you sure the MAT file and corresponding textures are for V3? Are you using V3 (Victoria 3 in the character library) or Vicki 3 to Vicki 2? You really need to give us more info to help you out. Cheers!
Alastor_God posted Fri, 10 January 2003 at 3:58 PM
i used V3 i dled the pack with mat v3 make up and i used the russet i dont know what else i could tell you
LaurieA posted Fri, 10 January 2003 at 4:06 PM
I think the makeup mats only change the face. You still need to apply the total body map before you apply the russet makup mat. Try that and see if that doesn't work for you :o). Laurie
Cyris posted Tue, 14 January 2003 at 8:51 AM
I have the same problem. when i use the "new" matfile to use the V2 texture on V i got this result :-((
