Hi! guys....
What about the right thing to decode a pcf encode object?
I try to decode a pcf for rfog in zygoteAnimals( frog)
Did i have to rename the new decode file???
did i have to delete the old obj(frog)????
I try to do my best... because i'm not so good in english.
If you can joint pictures to show me how... i will very appreciate.
Thank's..... Thedouf
Ok, first DO NOT delete the frog object in zygoteanimals, this is the orginal frog and you will need it for the seed. To decode the frog pcf object, select the decode button in Objaction Mover, enter the orginal frog object in your zygoteanimals folder as the seed, enter the pcf file as the difference file, and your new decode file should be listed as the figure file. You may need to rename the figure file if it has the same name as the orginal zygote frog. See attached pic. There are two errors you might end up seeing: 'Range check error' this means the object used for the seed (the orginal frog object) does not perfectly match the frog object on your hard drive. May be an updated or different frog object altogether was used to encode it. 'file access denied' this happens when any of the files involved are write protected. You'll need to check the properties for each file and uncheck read-only.
