Ang25 opened this issue on Jan 12, 2003 ยท 6 posts
Ang25 posted Sun, 12 January 2003 at 6:32 PM
ttops posted Sun, 12 January 2003 at 8:33 PM
That looks much better compared to your first post. Love the way the dead land seems to come to life inside the frame.
pmoores posted Sun, 12 January 2003 at 9:41 PM
Like that mirror or is it a portal? Ill tone down the bone diffusion a little though to make it older and worn.
lsstrout posted Mon, 13 January 2003 at 1:49 PM
I also love the contrast between the dead land and the mirror. This looks great! Worn bone is a good idea - you could change it and do a plop render. Lin
Ang25 posted Mon, 13 January 2003 at 2:01 PM
Thanks for the advice. I'll try to age the arm. And in case anyone is curious, it is a mirror. I had a heck of a time getting the green hills behind the camera to line up so that they showed in the mirror. One of my niggleys is the little spot of blue near the bottom of the mirror, its the sky showing not water. Not sure if I should leave it there and pretend its water or move the hills more to get rid of it. :) This was a very forgiving render, under a half hour I think so it shouldn't be a problem redoing some stuff in it. Ok thanks again.
Ang25 posted Mon, 13 January 2003 at 2:02 PM
And I'll try that plop render trick and see if I can get it to work too. Thanks Lin.
