Rita opened this issue on Apr 29, 2000 ยท 21 posts
Rita posted Sat, 29 April 2000 at 9:45 AM
robert.sharkey posted Sat, 29 April 2000 at 10:16 AM
With the geometry of this figures the best result you will receive at this way: 1. Load the object-file to UVMapper (see at the utilities-section) 2. Make a new UV-Map with settings "planar/z-axis/don't split" 3. save the new object under new filename 4. save texture template 5. colour the new template in your painting programm 6. load the new object in Bryce and apply the new texture That's it. SHARKEY
bonestructure posted Sat, 29 April 2000 at 12:41 PM
Uh, Painter 3D has the same hateful, annoying interface that Painter has. I've tried Painter, and I have Painter 3d, and as far as I can tell the only difference between the two is 3d's 3d capabilities. Everything else is exactly the same.
Rita posted Sat, 29 April 2000 at 1:34 PM
Thank you so much
bonestructure posted Sat, 29 April 2000 at 2:17 PM
actually Rita, tho I dislike the GUI in Painter 3D, I do like the capability of the program. Because of the fact that when you create a texture map in the 3D capabilities, it creates the tex, bump, glow, reflect and all the maps at the same time. So you have a multilayer map that I, at least, can then import into my Bryce materials library. I haven't tried it yet, but I'm assuming it's possible because when I try to import a map into the library now, it tells me it needs a multilayered tiff. So I'm thinking Painter 3D can do that. Oh, to get to that library by the way, apply any texture, go to the material editor, alt/shift click on the name of the texture map and that should being up the map library.
Dr Zik posted Sat, 29 April 2000 at 2:18 PM
Hi Folks! Am I the only person who experiences problems actually mapping a texture I create in Painter 3D onto a poser object? I imported some of the clothing obj files (such as West's bra/bikini top, for example) and composed some nice textures, but the coordinates are all screwed up. The texture either shows up on the back rather than front or only in a small portion of the object. All this after creating new templates with Steve's UV Mapper. Maybe someone can offer some insights. Peter (Dr Zik)
bonestructure posted Sat, 29 April 2000 at 2:34 PM
I have that problem too. I have no idea what causes it. I try to use textures and poser applies em in what seems like a random manner all the hell over the figure
Talos posted Sat, 29 April 2000 at 3:33 PM
Are we talking full registered Painter 3D here, or the free shareware version that came with Poser 4, and what is the difference ?
bonestructure posted Sat, 29 April 2000 at 3:47 PM
Mine is the full version
Rita posted Sat, 29 April 2000 at 5:09 PM
You're getting me all confused now. I'm new at this although not new with Poser. I downloaded Steve's UV Mapper. Can I use Paint Shop Pro6 or should I try to make textures in Painter3D? This is the one that came with Poser4.
bonestructure posted Sat, 29 April 2000 at 5:29 PM
Rita, why don't you search on the web for pictures of flamingos, cut and paste the texture from photos till you have a reasonably large, say 300 by 300 picture, then go into materials editor and use the picture as a texture. reverse the uh, transparency or whatever it is, the first black white button over the second window in the picture editor thingie. That will give you brighter colors. Play with reflection and transparency and the dte until you get something that looks right. apply it to one of the objects to see how it looks, and when it looks good go to the material editor, users, and just click add to add it to your materials.
Rita posted Sat, 29 April 2000 at 5:36 PM
I gather I do this all in Bryce? If so sounds good to me.
bloodsong posted Sat, 29 April 2000 at 6:33 PM
heya; remember, the texture map you get from painter3d has to be flipped vertically before you apply it in poser.
bonestructure posted Sat, 29 April 2000 at 6:37 PM
no, you have to have photoshop or something similar to make the picture. Try to find a large picture of a flamingo. Grab it and then in whatever art program you have, find a nice big square of pure texture, select that, cut it out of the pic and save it as a new image. Then go into bryce, on your object, click on the m to get the materials editor. Click on the second button from the left to bring up the little gold man, then click on the top button directly above that to get the loader. You'll see three windows, the first is alpha, the second is, I think transparency, and the thirs is a combination of both. Click where it says load, and go thru the files to find the picture you just made. Load that. Do the same thing in the second window, Since you're in Bryce 3, you'll need to look above the second window to find a button that's half black and half white. Click that to reverse the transparency, which will make your texture brighter. Then adjust your settings in the materials editor like always. I'd say set diffusion and ambiance to your picture, and set the rest to colors if you want, Maybe set bump to the picture. Then, if you need to, click the top left button and start scaling and moving the texture around. Apply it to your model, then, if you like it, click on the edit arrow to bring up the library, and just add the material you just made to the library. Are you confused yet? lol
bonestructure posted Sat, 29 April 2000 at 6:41 PM
Bloodsong, you want to explain that to me? I'm still rather new to poser
bonestructure posted Sat, 29 April 2000 at 9:29 PM
well, I'm having problems just applying normal images downloaded off the net, clothing maps and stuff. None of those seem to be upside down, they just seem to apply randomly on opposed halves of the body, half the head, half of one foot, scattered all over the body. I don't get it at all
Nance posted Sat, 29 April 2000 at 10:23 PM
bonestructure, it just sounds like you are applying the maps to the wrong figures. Like putting P3 maps on P4 figures. Got a specific example of one that comes out whacky for you?
Dr Zik posted Sat, 29 April 2000 at 11:24 PM
Hi Folks! Allie, thanx for the "flip tip." I'll try it as soon as exams are over!! Peter (Dr Zik)
Rita posted Sun, 30 April 2000 at 4:56 AM
LOL Bonestructure! Confused? Nah (as she let's out a bloodcurdling scream!!!!)I've got about 10 screen captures so I can see everyone's replies to try out. I just wish there was an easier way to print out all this info. I am one of those who follow the printed word.That's why I love tutorials. Hint, hint,Allerleirauh. Thanks all.
bonestructure posted Sun, 30 April 2000 at 4:32 PM
Nance, that may be the problem. But I have stuff I've downloaded, particularly clothing stuff, that didn't say it was for any particular figure. How do I know what figure to apply it to?
Nance posted Mon, 01 May 2000 at 1:48 AM
Oh, now you're going to confuse me if you change the subject. Your first question was about matching maps to models. If the maps are not labeled,(pretty rare) you will just have to become familar with each of the different model's mapping layouts. You can use UVMapper to see what the map template for any .obj file looks like. With regard to matching clothing models to figures, you can assume, by default, that most clothing is for the P3 or P4 nude female figures. Pieces done for Zygotes NYW, Eve, or Victoria are usually indicated in the title or readme.
