TT opened this issue on Jan 14, 2003 ยท 17 posts
TT posted Tue, 14 January 2003 at 2:25 PM
"I like my species the way it is."
LaurieA posted Tue, 14 January 2003 at 2:50 PM
I've had that program with the Daz Dresscoat Italia, but only if I point my camera at it STRAIGHT from the back. If I move the camera just one degree either way left or right it snaps back. Odd. Laurie
LaurieA posted Tue, 14 January 2003 at 2:51 PM
problem, not "program"...sheesh.
Crescent posted Tue, 14 January 2003 at 3:12 PM
If you're on P4, delete the .rsr that resides in the Geometries folder. If that gets corrupted then weirdnesses like that happen. LaurieA is right, if the camera is exactly 180 degrees, Poser freaks out and displays wacky stuff. Try moving the camera just slightly off to the left or right. It's a problem with Poser, not the robes.
LaurieA posted Tue, 14 January 2003 at 3:38 PM
Well, I don't know if that being a problem with Poser and not the robe is good or bad ;o). Laurie
TT posted Tue, 14 January 2003 at 4:14 PM
Thanks but I do know how to delete .rsrs that is not the problem Poser dont even load that case the figures if they ar corrupted, so that was not new. Crescent or anybody else do You have that Robe and can do couple renders with it to show how it looks like in backview and side views on V3.
pizazz posted Tue, 14 January 2003 at 7:41 PM
pizazz posted Tue, 14 January 2003 at 7:42 PM
pendarian posted Wed, 15 January 2003 at 12:42 AM
I have it, but had not used it yet. What I did just notice though was when I rotate V3 it does this, but if I choose the main camera and rotate it then it doesn't happen. Pendy
hauksdottir posted Wed, 15 January 2003 at 4:09 AM
TT posted Wed, 15 January 2003 at 5:53 AM
hauksdottir
pizazz posted Wed, 15 January 2003 at 6:56 AM
I don't have time to do more renders this morning, but I did NOT have IK turned off on V3. When I turned it off, the robe looks great with the main camera Y setting @180. You get up to 220-227 you can see the stretching on the fabric. The robe itself does not have the IK turned on.
Wynter posted Wed, 15 January 2003 at 8:33 AM
I don't know why this is happening but I'll check into it. The wonderful wierdness of Poser. :p We'll see if we can't fix it. ct
TT posted Wed, 15 January 2003 at 11:10 AM
Great CT, try to find fix so I can use it!:)
Wynter posted Wed, 15 January 2003 at 11:36 AM
Ok, its my wierdness and not Poser's! First the texture map and now this. And as all problems come in 3s there's bound to be another one. Okay, I don't know how it happened but the cr2 was missing "otherActor" info. So the head and the rThigh did not know they were supposed to act along with their neighboring body parts. I have sent the fix to Daz and there should be an updated cr2 on the product page later on, probably by this evening. BTW, I would like to note that this is "Optimized" version for V3. It was not "made" for her. So their are going to be issues with body parts sticking out due to the fact her geometry is different complicated by the JCMs. So if there is "poke through" some adjustments will be required. Future V3 clothing will be tailored to fit her geometry. Thanks, for your patience
TT posted Wed, 15 January 2003 at 1:54 PM
I will see forward for the updates and Thanks CT, we do have patiens :)sometimes ;).
hauksdottir posted Thu, 16 January 2003 at 3:31 AM
Thanks, Wynter. I'm glad that it is so easily fixed.
