peterfl opened this issue on Jan 17, 2003 ยท 5 posts
peterfl posted Fri, 17 January 2003 at 10:43 AM
I can't figure out how to import a Poser4 animation in to Bryce 5. I would like to add it to an allready made scene. Is this possible?
thgeisel posted Fri, 17 January 2003 at 11:04 AM
Attached Link: http://www.ev.ca/konan/natural_pose.htm
follow the linkpeterfl posted Fri, 17 January 2003 at 12:17 PM
Thanks for the info but it won't import a Poser animation. Error says it couldn't load obj file. It's a rendered and saved poser animation. I'm stumped.
RaysOfLight posted Fri, 17 January 2003 at 12:24 PM
why don't you try it the other way round? poser allows you to import a videclip as your backdrop, so render your animation in bryce and then import the avi into poser. i've messed with that a bit a while ago, so i know it worked for me, hopefully it'll work for you too
peterfl posted Fri, 17 January 2003 at 12:36 PM
Got the same error. "Error clicking Export OBJ file" It hangs at the Save As window. I've tried leaving it alone and tried naming it but I get the same error each time.
