inuyasha opened this issue on Jan 17, 2003 ยท 12 posts
inuyasha posted Fri, 17 January 2003 at 1:40 PM
Does someone know a program for creating grass for bryce 5?
madmax_br5 posted Fri, 17 January 2003 at 1:53 PM
Make a tree in bryce 5. Make the leaves "bamboo" shape. Make number of leaves 8, and size of leaves 1 or 2. Make the trunk material completely invisible (in the material lab, make transparency 100% and turn on blend transparency.) Then make the leaf material green. Now, duplicate the tree a few times, spread them out into a big clump, and place them all just so they poke out of the ground. Tada!
Aldaron posted Fri, 17 January 2003 at 2:35 PM
There is a program that produces grass models out there but I can't find it right now. Maybe someone else has the link.
tjohn posted Fri, 17 January 2003 at 2:39 PM
Attached Link: http://bantam3d.com/grass/index.htm
Here is the freeware that I think Aldaron was talking about. "grass" from Bantam 3DThis is not my "second childhood". I'm not finished with the first one yet.
BillyM67 posted Fri, 17 January 2003 at 2:52 PM
If you search through the "Free Stuff" section, someone put a material for grass on there quite a while back. Also, you can go to www.3dplants.com and she has one for free, plus a ton of nice plants for free as well!
AgentSmith posted Fri, 17 January 2003 at 6:32 PM
Bantam is nice, pretty easy to use, but with advanced settings/abilities if you want them. (And it's FREE) 3D Cafe has a few good grass-type meshes; http://www.3dcafe.com/asp/meshes.asp
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
AgentSmith posted Fri, 17 January 2003 at 6:34 PM
Freestuff | IMDB
Credits | Personal
Site
shadowdragonlord posted Fri, 17 January 2003 at 7:17 PM
Flak posted Fri, 17 January 2003 at 10:52 PM
Attached Link: http://www.geocities.com/imanonymis/sfx3d/grass.htm
A grass tut I've used for a non-modelling approach at getting grass into a large field.Dreams are just nightmares on prozac...
Digital
WasteLanD
FWTempest posted Fri, 17 January 2003 at 11:39 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=275057
Then there's this method.... brief explanation of how the grass was done is in narrative below image.FWTempest posted Fri, 17 January 2003 at 11:41 PM
btw, Flak... I hadn't seen that tutorial, gotta try that one sometime... thanks for sharing.
Hepcatbrandon posted Sun, 19 January 2003 at 12:31 AM
You can also paint spikes onto a high resolution terrain for a nice mown grass effect
