Subject: How To UV Map V3 to use V2 Maps *pix*
Simderella opened this issue on Jan 18, 2003 ยท 72 posts
Simderella posted Sat, 18 January 2003 at 11:06 AM
Ok... I've seen quite a few people post about how to do this. and i know the text guide acn be a bit 'HUH???' if your not used to using Uv mapper or perhaps you feel abit daunted by all the techie poser speak.. LOL ;) So here is how i did it and some useful (hopefully) pix as a guide. -=SimderZ=- ok... here we go..... Step One + Open UV Mapper *u can get for free at: www.uvmapper.com* i think thats the right URL!!! + go to FILE - LOAD MODEL
Simderella posted Sat, 18 January 2003 at 11:12 AM
+ Locate your blMilWom_v3.obj file in you Poser directory in Geometries 'DAZ People' + click open + you should see this appear after it loads
dialyn posted Sat, 18 January 2003 at 11:15 AM
I'm signing on for the rest of this tutorial. I can't make heads or tails out of the UV Mapper. Thank you for doing this!!!
Simderella posted Sat, 18 January 2003 at 11:16 AM
+ go to FILE - import UV's + find where you saved the new Uv's from DAZ and load up: blMilWom_V3_V2UVs.uvs + you should see this:
Simderella posted Sat, 18 January 2003 at 11:20 AM
almost done!! + Now go to FILE - Save Model + a window will pop up with an array of mind boggling selections.. + make sure ONLY: Export Uv Coordinates & Export Materials are selected *see pic* + The save your new figure as something like: blMilWom_V3_UV.obj save it to the geometries file DAZ PEOPLE
Momcat posted Sat, 18 January 2003 at 11:25 AM
Does this replace V3's mapping with V2's? Is there a way to do this so I can keep one version of V3 with V3 mapping, and another with V2 mapping?
thgeisel posted Sat, 18 January 2003 at 11:27 AM
yes momcat, you can keep both beside each other
Simderella posted Sat, 18 January 2003 at 11:33 AM
now heres the slightly tricky part, but its not really!!! LOL + Locate your Victoria 3.cr2 file, usually found here: C:Program FilesMetaCreationsPoser 4RuntimeLibrariescharacterDAZ People + COPY & PASTE it to the same directory, it will pop up called something like 'Copy of Victoria 3' + open it with a text editor (i used word pad) + goto EDIT - REPLACE + in the top line 'FIND what' put in blMilWom_v3.obj secind line 'REPLACE with' put in blMilWom_V3_UV.obj or whatever you named your new obj file we created earlier. + now when thats down just click SAVE (not save as) + remember to rename your newly created cr2 File, you don't want it called 'Copy of Victoria 3' LOL.. so call it something like Victoria 3 UV + Load up poser, go to FIGURES open your DAZ PEOPLE library and there should be your new figure, she won't have a picture just that strange person with there hands up, you can create a PNG for her later! or resave her when you have injected the V3 morphs into her!! Now go and render away, apply all those gorgeous V2 textures you thought you'd never be able to use on your gorgeous shiney new V3!!! I really hope that helped.. If anything was unclear i will do my best to clear it up!!! HUGZ Happy rendering -=SimderZ=- *ps i am aware there is an error with the right nipple & apllying mat files... I think there is a new UV file out there to correct this problem. If someone knows where it is post it here, then all you'd need to do is repeat all the steps but use the corrected UV instead of the DAZ one!!!
Simderella posted Sat, 18 January 2003 at 11:35 AM
"Does this replace V3's mapping with V2's? Is there a way to do this so I can keep one version of V3 with V3 mapping, and another with V2 mapping? " nope it just creates a NEW V3 figure that is able to use V2 textures, and still use all of V's morph injections.. It won't replace anything, you'll still have you main V3 and V2... This newly remapped V3 however cannot take V3 textures anymore, as she is remapped to tell Poser to where it should put V2 textureson V3's changed body geometries.. :) hope that helped! -=SimderZ=-
Simderella posted Sat, 18 January 2003 at 11:47 AM
OK.... i found the link to the corrected UV file.. It correctes the error in DAZ's UV's that made V3 remapped right nipple not show up when using V2 textures... http://www.thenetherworks.com/Mesh/Victoria3to2UVfix.zip simply use that UV instead of blMilWom_V3_V2UVs.uvs i mentioned in STEP THREE and all should be peachy!!! Have Fun -=SimderZ=-
Momcat posted Sat, 18 January 2003 at 11:57 AM
Curious: Can you still use body glove, or Second Skin MATs on the remapped V3?
Simderella posted Sat, 18 January 2003 at 12:05 PM
Nope.. she will only take V2 textures now.. just use normal V3 for that. Here is my remapped Victoria Three using BlackHearted's Elowen V2 textures.. ;) looking fine and dandy... she is wearing the V3 Bikini and V3 Bombshell hair! -=SimderZ=-
lululee posted Sat, 18 January 2003 at 12:08 PM Online Now!
Thank you, Thank you, Thank you, Thank you, !!! You are a champ.
Simderella posted Sat, 18 January 2003 at 12:11 PM
giggles it was my pleasure!!! let me know how it worked for you, i would love to see pix hugz -=SimderZ=-
BecSchm posted Sat, 18 January 2003 at 12:17 PM
Thank U from me 2!
BecSchm posted Sat, 18 January 2003 at 12:58 PM
Vic3 with Vic2 Texture (V2 eyes by Catharina Harders). It worked really well!
tasquah posted Sat, 18 January 2003 at 1:17 PM
Just a side note to say you need to do the conversion AFTER you have run the V3 updates because there were 2 problum areas in the UV map that get fixed in the updates.
Vazdru posted Sat, 18 January 2003 at 2:22 PM
excellent!! I will have to tackle this after my son goes to sleep! (so I can think in a complete sentence!!) smooch thank you for the tutorial, hunny! without the pics, I'd never figure it out! -Batty-
rbtwhiz posted Sat, 18 January 2003 at 2:24 PM
"*ps i am aware there is an error with the right nipple & apllying mat files... I think there is a new UV file out there to correct this problem. If someone knows where it is post it here, then all you'd need to do is repeat all the steps but use the corrected UV instead of the DAZ one!!!"
http://store.daz3d.com/Update/V3-servicerelease1.html
The uvs download on the Victoria 3 product page was updated with sr1.
-Rob
dragongirl posted Sat, 18 January 2003 at 2:33 PM
THANK YOU!! I really needed pictures to understand it. :-) -dg
EricofSD posted Sat, 18 January 2003 at 2:36 PM
er.... What did I do wrong? I only found two instances of bimilwom in the cr2 by manually scrolling, both near the top. Did I miss more? Find / replace doesn't work for me. Win2k wordpad.
MachineClaw posted Sat, 18 January 2003 at 2:43 PM
Thanks for the picture tut. This sure makes it straight forward and simple. Really appricate it.
EricofSD posted Sat, 18 January 2003 at 2:45 PM
i can say this, I was working with the sr1 stuff from daz. And there's two uv's. One is blMilWom_V3_V2UVs.uvs that you listed and that's what I used in uvmapper. There's another from daz called blMilWom_V3_V2UVs-mat.uvs which i did not use in uvmapper.
Simderella posted Sat, 18 January 2003 at 3:12 PM
hmmm thats weird.. it didn't do that for me... very odd!!! what texture did u apply? and yes there are only 2 intances that u have to change... I am stumped.. i haven't encountered that problem.. i'm sorry.. hmmmm
Simderella posted Sat, 18 January 2003 at 3:17 PM
Maybe if you tell me what you called ur newly remapped V3 obj i can create a Cr2 for you :)
thgeisel posted Sat, 18 January 2003 at 3:18 PM
you have to use the uv-file with "mat" in the name.otherwise matposes are not working
tasquah posted Sat, 18 January 2003 at 3:32 PM
nope i just tried that out becasue i was getting the same thing . Were EricofSD went wrong was in the step 4 part . I believe that there was more checked than the 2 or that was what i did wrong . I also used the NEW sr1 CR2 though.
Blazerwiccan posted Sat, 18 January 2003 at 3:37 PM
Well I hate to sound dumb and all and it seems no one else is haveing this problem. I went thought he steps as listed here all worked well but one thing. Each time I try to put textures on the Vicki3 /Vicki 2 UV's Character all works but her eyes. Her eyes are just white, no textures shows after rendering but shows in Poser. Not sure what I am doing wrong. I mean the eyes look cool like this lol but I want them to actally use the eye textures. Any ideas? Thanks for any help. Image attached straight out of Poser, cwshorty's Tasmen texture used.
tasquah posted Sat, 18 January 2003 at 3:37 PM
opps didnt mean no to thgeisel just about what possibly went wrong in the conversion. Mine is taking the v2 textures now .
Blazerwiccan posted Sat, 18 January 2003 at 3:40 PM
cwshorty's Tamsen texture is what I ment to type. I hate typos lol.
BecSchm posted Sat, 18 January 2003 at 3:50 PM
Blazerwiccan - for some reason the "strength" setting under the texture map for the eyes on V3 seems to set itself to 0%. If you reset all eyeparts to 100% strength, all seems to be fixed. That's what has happened to me sometimes, anyway.
Blazerwiccan posted Sat, 18 January 2003 at 4:13 PM
BecSchm Thanks that worked. :) Yay now I have more I can play with for Vicki3. Thanks Simderella for posting this and BecSchm for your help. My Victoria 3 is so very happy now.
EricofSD posted Sat, 18 January 2003 at 4:43 PM
I was careful to only check the two boxes in step 4. I'm sure i got that right. I can try again with the -mat file. I tried several textures. Some from the AtoZ collection, some from the Essence of Beauty collection for the milgirls which map perfectly on to Vickie Lo res. I'm pretty sure I had some V2 textures that I tried but not positive about that. Maybe that's an issue.
EricofSD posted Sat, 18 January 2003 at 5:05 PM
thgeisel, that was the fix, had to use the -mat one.
tasquah posted Sat, 18 January 2003 at 5:34 PM
Yep I was wrong , I thought i was useing the Regular UV but I was useing the Mat one.
Porthos posted Sat, 18 January 2003 at 5:36 PM
V3 wearing StefyZZ Asia Texture!
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
Simderella posted Sat, 18 January 2003 at 6:18 PM
well, you all seem to have worked it out! which is kewl.. and i'm glad i could help bring more variety to your V3! Its kewl to be able to use all thise great V2 textures again!!! Have Fun! -=SimderZ=-
Marque posted Sat, 18 January 2003 at 7:08 PM
Must be nice, mine never did work. I did exactly what you said twice, even re-installed V3 and the maps twice. Marque
tasquah posted Sat, 18 January 2003 at 7:28 PM
Marque , DId you try useing the V3UVs map converted object ? And can you post a sample of what you get thats not working? We might be able to walk you through were you might have went wrong .
EricofSD posted Sat, 18 January 2003 at 7:43 PM
Simderella, you're an angel. Thanks so much for the tut. V3, Bombshell, Essence of Innosence texture/eyes, Dreamer wings.
mabfairyqueen posted Sat, 18 January 2003 at 8:09 PM
This is wonderful, thanks Simderella! Can this same process be done the other way around? I would like to use V3's textures cooridinates on the "V3 to V2" version of V3. Is there a way to do that? Wondering if anyone has tried it. I tried it, but I might have done something wrong, because it didn't work.
tasquah posted Sat, 18 January 2003 at 8:29 PM
mabfairyqueen you should still have a regular V3 to use V3 textures on . Unless you mean a regular V2 to use V3 textures. Darn now i am confused.
mabfairyqueen posted Sat, 18 January 2003 at 9:08 PM
I meant the V3-to-V2 version of V3, but I've been told her mesh doesn't match up with regular V3's mesh in the body and so it won't work. Is that true?
tasquah posted Sat, 18 January 2003 at 9:20 PM
I would say yes thats true, it will not work to use a V3 texture on it after its been converted. What part were you thinking of useing if you dont mind shareing ? Might be another way to do it.
mabfairyqueen posted Sat, 18 January 2003 at 9:43 PM
Well, while waiting for clothes for V3's slightly more complex cr2 to be made, I was hoping to use the V3toV2 version of her to clothe a particular scifi character I've made using regular V3 with the hi-res V3 mapping at daz. I'd like the mapping for the character to match on the V3toV2 version as well so that I can expand her wardrobe in the mean time. I love the new mapping of V3 way, way, way better than original V, nice as her mapping was at the time, and I don't want to go back. Plus, I've already established this character's look where I'm using her at using the hi-res daz v3 textures maps. Thus my delimma. If there was a way to just remap the head to V3's head mapping, that would do. I could modify a body texture I already have for original V to do for the body.
ford3auss posted Sat, 18 January 2003 at 10:19 PM
Thanks for the tut, would you be able to but the tut into a pdf file or some thing so we can download it for a later date eg; if i reformat at a later date i will never remember how to do it,, thanks for you time...
MiKo0 posted Sun, 19 January 2003 at 5:33 AM
Works perfect for me...Tried it the other day when you posted on my post about it :) Though I did get a little worried, when I loaded her in Poser, her skin came up a nice shade of brown with a default pale head..but she rendered ok
Simderella posted Sun, 19 January 2003 at 7:47 AM
I'm so glad that i was able to help! :) I would love to put this in a pdf file, but i don't appear to have something to create that file.. I have the adobe reader, but i can't create one... How would i do it? I have put together more pix and stuff to make one I have it all ready to do.... can i download this product for free anywhere... Many Thanks & Hugz -=SimderZ=-
Simderella posted Sun, 19 January 2003 at 8:47 AM
ok... I have created a PDF file of this tutorial.. I will upload it and give you all the URL.. the file is about 759kb!!! This file will be available for download for one month so grab it now! Or I will email it to you :) http://homepage.ntlworld.com/vayne_xianah/SimderZ/How_To_Uv_Map_V3.zip -=SimderZ=-
jobcontrol posted Sun, 19 January 2003 at 2:24 PM
Thanks a lot, SimderZ! I got it. It made a few things clear to me I didn't understand before. Willy
Simderella posted Sun, 19 January 2003 at 4:16 PM
No probs ;)
ford3auss posted Sun, 19 January 2003 at 4:27 PM
Thank you,Thank you so very much for the pdf, its great..
Simderella posted Mon, 20 January 2003 at 7:50 AM
I'm glad i could help!!! Have fun :) -=SimderZ=-
Simderella posted Mon, 20 January 2003 at 2:51 PM
just a note: I have had to delete the PDF from my server as i am having problems with my ftp... so if anyone else wants this, please feel free to email me and i will send it to you. digitaldarings@ntlworld.com please mark ur subject header as 'V3 PDF' Thanks, and glad i was able to help :) -=SimderZ=-
tasquah posted Mon, 20 January 2003 at 8:18 PM
I can put it up on mine and you can send / post the url for it if you want Simderella. It not a poser site though just a personal one.
thundr posted Fri, 24 January 2003 at 11:59 AM
I don't know what I did wrong but it's still not working for me. I'm getting the same thing EricofSD did, and I tried both ways...using the UV with -mat and the other without. Still no dice. I can't understand what's going wrong.
SophiaDeer posted Mon, 27 January 2003 at 2:23 AM
Thank you so much, Simderella!
You are a Saint! It worked for me and I am most grateful to you.
Here is Vic3 wearing Angelmoon's Luna2 Moonlight Goddess texture:
Thank you so very, very much!
Hugs,
Nancy Deer With Horns (SophiaDeer)
Deer With Horns Native American Indian Site
Marque posted Mon, 27 January 2003 at 9:05 AM
sigh
thundr posted Mon, 27 January 2003 at 10:58 AM
well, I can get things to sort of work if I go in to the materials menu and fix all of the materials by hand otherwise I nada. It's a real pain to have to go and remap any model that i want to use... Hey Marque If you get your's fixed post here and let me know how you fixed it. Maybe Simderella will see this and help us out.
Marque posted Mon, 27 January 2003 at 11:46 AM
So are these only usable in 3D Max? Thanks, Marque
Dark_Whisper posted Wed, 29 January 2003 at 6:01 AM
Attached Link: V2-V3 Texture Convertor
Hi guys, I have just developed an application that converts the actual textures from V2->V3 format, and from V3->V2 format. As this is exactly what would solve several issues raised in this thread, I thought I'd mention it :-) cheers, Steve
Kurgen posted Wed, 29 January 2003 at 10:07 PM
umm i might be totaly off trak here but the head issue above looks like the v2 head texture hasnt been applied to the new V3 Scalp body part? you checked this in the materials editor?
Kurgen posted Wed, 29 January 2003 at 10:09 PM
opps back to front! lol looks like the Scalp has had a tex applied but not the face
thundr posted Thu, 30 January 2003 at 10:01 AM
Finally got this to work. Don't know why it work this 5 time as I didn't do anything different but it worked!
Larry F posted Fri, 31 January 2003 at 9:25 PM
Wow! The things one can find when looking through archives! Great stuff! Thanks. Larry F
arrow1 posted Tue, 04 February 2003 at 1:49 AM
Hi,I am attempting to do your tutorial on using V3 to use V2 maps.I am not sure about a couple of things in wordpad or notepad. You say go to EDIT-REPLACE ok so far and the placement of the obj's is fine in the Find What and Replace,but is the next line I am having trouble with where you say ,when that is down hit save(not save as.This is my question.Do you hit replace or replace all and then close the text editor and then save or if not what do you do? Also do you use the UV FILE UVS MAT or the one without Mat.I would appreciate any help as I have never used a text editor before. Cheers arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
arrow1 posted Tue, 04 February 2003 at 1:57 AM
arrow1 again.Can I add a PS.Do you use the V3 Blank or V3 herself? Cheers arrow1
fretshredder posted Sat, 05 April 2003 at 12:23 PM
thank you for this lovely tut. However, it should be mentioned that UVMapper is not free ... it's $49.95 (I think).. There is a DEMO, but it is save-disabled :-(
Momcat posted Sat, 05 April 2003 at 12:34 PM
Attached Link: http://www.uvmapper.com/uvmapper.htm
UV mapper is indeed free. UV Mapper Pro is not. UV Mapper (free version) is now known as UV MApper Classic.
MachineClaw posted Sat, 05 April 2003 at 12:35 PM
UVMapper (Now called Classic) is free and saves. UVMapper Professional is $49.95 and has additional features, but those features are not needed for this tutorial. This tutorial works fine with UVMapper Classic. I've included a link to UVMapper web site. UVMapper Classic is down the page under the UVMapper professional information.
fretshredder posted Sat, 05 April 2003 at 2:18 PM
ahh! that would make sense... thanks for the clarification :-)
Simderella posted Tue, 29 April 2003 at 12:30 PM
i'm really glad i could help!!! I think i mentioned i have this tutorial in PDF format with more instruction.. so if anyone wants it drop me a line! -=SimderZ=-
