thehmc opened this issue on Jan 21, 2003 ยท 6 posts
thehmc posted Tue, 21 January 2003 at 12:30 PM
is there a way to do this. basically i want to render the background first. then render the people in the forground as a series of jpegs. when i render the people the background in the jpegs is just white. is there any way to make poser 4 render this series of pictures with transparent backgrounds so when i combine the fore and backgrounds only the people will be visible and not the white background.
bluetone posted Tue, 21 January 2003 at 3:28 PM
Not with JPEGs. The format doesn't support transparency, and if you tried to 'magic wand' (in Photoshop) the background white, you will find a very harsh edge of antialiasing that you can't remove! (I just love a sloppy standard, don't you?) Try TIFs or GIFs instead. (Of course I am Poser ignorant, so excuse me if Poser can't output that way.) :>
thehmc posted Tue, 21 January 2003 at 3:56 PM
actually it can render tiffs but those give me a white background as well. i'm wondering if there is a setting in poser 4 that i'm missing which will give me the option to render transparent backgrounds. i could go through each frame one by one and select them and delete the background in photoshop but that would take for-EVER.
bluetone posted Tue, 21 January 2003 at 6:20 PM
Is there an option for a "Mask", "Alpha Mask", or "Alpha Channel"? The TIF format supports alpha channels, and they allow for selecting the foreground and masking the background, i.e. your white background. As I mentioned before I don't have Poser to give you an accurate answer to your question, but this is how it is done with other programs. Good luck! :>
odeathoflife posted Tue, 28 January 2003 at 4:26 PM
The png format exports with no BG 8^)
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
thehmc posted Wed, 29 January 2003 at 3:52 PM
thanks... i did it using .png and it's perfect. thanx man
