evilded777 opened this issue on Jan 23, 2003 ยท 4 posts
evilded777 posted Thu, 23 January 2003 at 6:38 PM
Anyone ever get this error message: Not enough disk space to render at this resolution ? I've got 7 gigs on my boot drive and 32 on the drive where Poser lives. So I certainly have enough disk space. e.d.
seaayre posted Thu, 23 January 2003 at 11:31 PM
I've gotten it. Have no clue why tho. I think of it as a gremlin message. Closing Poser, reopening, and rendering again always seems to drive it away. :)
rogergordian posted Fri, 24 January 2003 at 3:27 AM
I'd only received this error message with Windows 2000 Pro and Windows XP. In simplistic terms, Poser sometimes has a conflict with your Windows swap file. My easy fix was to install Poser on a different hard drive than Windows. After that change, I rarely received the error message. If I did, it was time to defrag the hard drive. Curious Labs, and others, state that you can adjust your swap file to fix the problem. I always hesitate to change the swap file.
evilded777 posted Fri, 24 January 2003 at 7:10 AM
thanks for the hints, I was going to re-start the PC and try again, but had too many other things to do. I will try tonight and see if I can render at the res I want. best, e.d.
