ablc opened this issue on Jan 24, 2003 ยท 2 posts
ablc posted Fri, 24 January 2003 at 9:04 AM
yggdrasil posted Fri, 24 January 2003 at 11:59 AM
Did you make sure that Remove backfacing polygons was off? If so then it could be double sided polys. These can usually be fixed by attaching a noise node to the displacement channel of the material and setting a very low value (0.001). That allows Poser to separate the front and back parts of the poly and makes the renderer behave better. -- Mark
Mark
