Subject: Knowledgable computer people, HELP
dirk5027 opened this issue on Jan 24, 2003 ยท 9 posts
dirk5027 posted Fri, 24 January 2003 at 3:08 PM
I just got road runner(cable)and have enabled xp firewall..now poser 5 wants to freeze up a lot, any connection? It always worked fine,not the quickest thing in the world, but it never froze. 2gig 512 ddr ram
dirk5027 posted Fri, 24 January 2003 at 3:48 PM
thanks, no that's not it, i'm the only person with this serial number and poser doesn't connect anymore after the latest update
praxis22 posted Fri, 24 January 2003 at 3:52 PM
Attached Link: http://www.zonelabs.com
Does it work with the firewall turned off? If so, you can install zone alarm instead, which is a better firewall IMO, and it's free. later jb
dirk5027 posted Fri, 24 January 2003 at 4:43 PM
it worked for a while then froze and seemed slower, just wondering if having the cable connection is sucking up memory
Wadus posted Fri, 24 January 2003 at 5:10 PM
I have cable connection and I use zonealarm with no problems. the XP firwall only catches incoming traffic it doesn't get the outgoing traffic so I have it turn off. ZA lets you block anything you dont want to access the internet. and its free...
EricofSD posted Fri, 24 January 2003 at 7:49 PM
Black Ice is pretty good and its relatively cheap.
dirk5027 posted Fri, 24 January 2003 at 7:57 PM
i got zone alarm it's great thanks
JohnRender posted Mon, 27 January 2003 at 9:46 AM
The "cable connection" is not "sucking" any memory. The "connection" doesn't use any memory at all. Your data transfer reate (with programs that use the connection) will be increased. You may have to disable your XP firewall settings to let Poser do its thing. People have been using P5 and Windows XP and RoadRunner just fine for a long time. If turning off your firewall doesn't solve it, then you may have found yet another bug in Poser 5.
dirk5027 posted Mon, 27 January 2003 at 3:17 PM
thanks to all that answered this post, so the day i got road runner i downloaded realplayer one, not sure why but that was my problem all along, i uninstalled it and all is well, reason for this i have no clue
