Subject: Disappearing Looma face files?
artnik opened this issue on Jan 24, 2003 ยท 5 posts
artnik posted Fri, 24 January 2003 at 9:06 PM
I finally got around to installing Valentin's wonderful characters, Valerie, Ludevine and Looma. All the files show up in the Poser thumbs, except for Looma's face files. Instead of the thumbs, I get a blank with a darker brown oval shape on it. Any thoughts on the subject?
queri posted Sat, 25 January 2003 at 11:27 AM
Does the fc2 work? Does it apply to the the character? If so you can save this face to the folder. If not, you may have gotten a corrupted download. Emily
yggdrasil posted Sat, 25 January 2003 at 12:08 PM
If you are using P5 or ProPack then the problem is that the supplied .png files do not have any transparency set. Just delete the .png files from face/looma and P5/PPP will recreate them from the .rsr files the next time you open the library in Poser. I've found this happens quite often, if no .rsr is supplied with a package (Looma included both), then you can use PhotoShop or similar paint program to convert the non-transparent .png to a transparent one. -- Mark
Mark
Puntomaus posted Sat, 25 January 2003 at 12:35 PM
Or you can open these PNGs in Photoshop and go to Layer - Layer from background and resave them, that does the trick. And I think the new version of P3DO Explorer as the option not only to convert RSR to PNG but to fix blank PNGs as well.
Every organisation rests upon a mountain of secrets ~ Julian Assange
artnik posted Sat, 25 January 2003 at 2:15 PM
Thanks for the tip. Deleting the .png files worked. I'll remember this next time something like that happens.
