Subject: Problem With object file not being found when opening saved PZ3
Manikin Flesh opened this issue on Jan 28, 2003 ยท 3 posts
Manikin Flesh posted Tue, 28 January 2003 at 1:22 PM
Bought Stormguards yesterday. Put all the pieces on, mats, etc and saved it as a pz3. Try to load the pz3 and Poser says it can't open the obj file for the elbowpad. I have the Stormguards update. I am perplexed as I don't understand how it works fine in poser initially, but then can't find the object file when it is saved as a pz3. If it was a problem with the downloaded file from daz I assume it wouldn't work in poser at all. I deleted the rsr for the elbowpad but that didn't help. So if anyone has any ideas on what to do I appreciate it. Thanks, Bill
c1rcle posted Tue, 28 January 2003 at 1:36 PM
how about copying the obj to the folder where you have the pz3 file, not a perfect solution but you might be able to use it then.
Spit posted Tue, 28 January 2003 at 1:54 PM
I discovered that if the .obj has a space in the name, Poser can't find it when you load the PZ3. Check if that's the case. Ran into it with something a couple months ago.
