OReillyTX opened this issue on Jan 29, 2003 ยท 5 posts
OReillyTX posted Wed, 29 January 2003 at 12:08 PM
GraphicFoxx posted Wed, 29 January 2003 at 12:41 PM
In P5 render settings, make sure you change the maximum texture map size and minimum shading rate. By not changing it, P5 is basically altering your texture to be 1024 instead of your intended 4000. So up that to 4000 or 4096. And minimum shading rate is something I just discovered what it effects. I got the v3 active wear plus textures from DAZ, and the lace corset tex looked like a$$. By by lowering the shading rate, it made it look great. Default is 2.00 while production mode default is 0.500. I dropped it down to 0.001, and the texture turned out nice. I think this will help you, as the tex looked similar to how that leg hair looks. Hope that helps you out.
OReillyTX posted Wed, 29 January 2003 at 12:53 PM
That did the trick,THANK YOU SO VERY MUCH !
GraphicFoxx posted Wed, 29 January 2003 at 11:13 PM
Hey, no problem :)
Lyrra posted Wed, 29 January 2003 at 11:36 PM
