Forum: Photoshop
Subject: Converting actions.
JohnF1964 opened this issue on Jan 29, 2003 ยท 5 posts
JohnF1964 posted Wed, 29 January 2003 at 3:53 PM
Is it possible to convert a PS 6 action so it will work in PS 5? Thanks
Grimtwist posted Wed, 29 January 2003 at 5:37 PM
Have you tried it? I thought both versions were compatible.
retrocity posted Wed, 29 January 2003 at 10:50 PM
Most times an action won't "degrade" properly is if you are using functionality available only in the higher version. You also have to be mindful of "how" you call up the routine (keystroke shortcuts, menu pull-downs, point-click...) Other than that, try it and see if it works. Test it by changing your "playback options" of your actions to Step-by-Step and that will let you know where it toss's it cookies...
retrocity
PS. what type of action?
JohnF1964 posted Thu, 30 January 2003 at 5:10 PM
Thanks guys, but it still doesn't work, I just get a message that says it is incompatible with this version of photoshop. It's the Daz3d Millenium Eyemaker.
vdallas posted Wed, 05 February 2003 at 3:29 PM
Try converting the action to a text file. Print it out & study it. When you understand the action, it should be easy to re-record it in version 5. Maybe?
