Manikin Flesh opened this issue on Jan 30, 2003 ยท 14 posts
Manikin Flesh posted Thu, 30 January 2003 at 9:20 AM
Hi, The problem is when I save a character using the Stormguard uniform it comes back stating can't open "runtimegeometriesimstuffsentinalssvelbowpads.obj". The actual path is "runtimegeometriesimstuffStormguardssvelbowpads.obj I've contacted Daz tech support and they told me to delete the rsr which I had already done and that doesn't work, that took 24 hours. I haven't messed with cr2s much and am not sure as to whether or not the difference in paths could result in the problem I'm seeing. So if any of you could be so kind as to advise me as to whether I'm on the right track I'd appreciate it. It works fine in Poser, I only get the message when I reopen the saved pz3. Thanks, Bill
