Forum: Photoshop
Subject: Why do all the document icons become Quicktimes?
kelley opened this issue on Jan 30, 2003 ยท 8 posts
kelley posted Thu, 30 January 2003 at 6:00 PM
The title pretty much says it all. I save as .pds or .bmp, but when I go back to open the doc., the icon is Quicktime. This has happened also when I've saved bunches of images to a CD. Are they really Quicktimes?
JayPeG posted Thu, 30 January 2003 at 6:10 PM
Are you using Mac or Win? If you are on a Mac try rebuilding the desktop. Restart while holding down command and option until you see the message asking if you want to rebuild the desktop. Tell it yes. This usually helps when icons start taking on an appearance that they are not supposed to. If you are on Win, I have no idea. A Win user will have to help. Either way, the files you saved are most likely not Quicktime. If you save as a psd than is is a psd, it does not spontainiously become QT but someimes icons do get screwed up.
kruzr posted Thu, 30 January 2003 at 8:07 PM
I'm using Windows 98SE, & when my icons start acting up, such as your describing, I use a program called "Tweak UI" for repairing them. Hope that'll help'ya some . . . Mark.
kelley posted Thu, 30 January 2003 at 10:36 PM
OK...I'm a Mac fan, but this is on Windows XP. kruzr: where can I find "Tweak UI"? THanks for the help.
dreamer101 posted Thu, 30 January 2003 at 10:59 PM
Microsoft PowerToys for Windows XP You can't use the same version of Tweak UI on WinXP as on Win98.
kruzr posted Thu, 30 January 2003 at 11:46 PM
Yes sir . . . dreamer101 said it all, thanks. Good luck kelley, & have a good one . . . Mark.
bonestructure posted Sat, 01 February 2003 at 3:11 PM
If you're on Windows, right click the file in windows explorer, click open with, and in that window select the program you want as the default program to open tne file, then click always open files of this type with.
kelley posted Sat, 01 February 2003 at 9:05 PM
bonestructure: Thanks for the tip.
