Forum: Bryce
Subject: Question about Frame rates.
Acuos opened this issue on Feb 01, 2003 ยท 5 posts
Acuos posted Sat, 01 February 2003 at 8:45 AM
What would be a good frame rate for a medium quality animation? Acuos
Pedrith posted Sat, 01 February 2003 at 9:07 AM
Hi. The lowest frame rate a animation should hae with out looking to jumpy is 15 frames per second (fps). Film is 24 fps PAL format ( Tv in Europe) is 25 fps NTSC (north american tv) is 30 fps. :)
clay posted Sat, 01 February 2003 at 10:52 AM
If you're doing an animation for the web, 12-15 fps is what the standard is.
Do atleast one thing a day that scares the hell outta ya!!
Ornlu posted Sat, 01 February 2003 at 10:58 AM
Well, I just finished an anim 750 frames, 25 frames per second, a 30 second movie, only 2.5 megs, and each frame was 640 by 480. A lot depends on how you are post processing it. If you are rendering to avi or mov, use 15. If you are doing bmp sequence and post producing in another program, i'd go for something higher, 20-30.
Acuos posted Sat, 01 February 2003 at 5:41 PM
Thanks, I just need to make an ad for a class project. 15 it is.
