rob_hart opened this issue on Feb 02, 2003 ยท 6 posts
rob_hart posted Sun, 02 February 2003 at 12:03 AM
Hey there - any help would be appreciated. I'm running Poser 4.03 on my 400MHz Mac laptop - I've got over 500 MB of RAM. Whenever I make an animation and use the make movie command, it freezes when it is done making the movie. The movie is fine but I have to restart my computer. I'm exporting using Animation, anti-aliasing on, 29.97 fps, keyframe every 24. I've also tried without keyframing, without anti-aliasing and at 30 fps. I've also tried it on my G4. Same story. Any help! It's driving me bonkers! Thanks, Rob
andygraph posted Sun, 02 February 2003 at 1:01 AM
Quicktime 6 is not compatible with poser. Back to quicktime 5 its better way for fix your problem. Andygraph
Estruch posted Sun, 02 February 2003 at 3:17 AM
I have also this problem. I work with QuickTime 5, and delete QT 6.
MungoPark posted Sun, 02 February 2003 at 3:32 AM
Heres a better way - do not render directly into a movie - you have much more control over the final movie if you render into a sequence of single tiffs. Then load the sequence into Quicktime, and export it as movie - but you need QuicktimePro in order to make this. The advantage is that you can test any type of compression you want - if you render directly into a movie and when you recompress it, you will get unpredictable results. Mungo
jerr3d posted Sun, 02 February 2003 at 10:53 AM
What a pain huh? Don't delete Quicktime 6, you will need it to view Quicktime 6 movies. So make a seperate extension set with 6 and one with 5, Run Poser under QT 5 If you forget and render a movie under QT 6, after the movie renders, you can then force quit Poser. This will at least keep your system from freezing up.
doozy posted Thu, 06 February 2003 at 4:09 PM
Read more about this in the "Macintosh" forum here.
