bakabaka1 opened this issue on Feb 02, 2003 ยท 2 posts
bakabaka1 posted Sun, 02 February 2003 at 6:20 PM
Ok I looked at the tutorial for the atmospheric lighting in Poser 5 and got excited and gave it a try....to no avile So i tried it again on a later day and still no lighting. So i tryed on my own just messing around...Didn't work so can ayone help me or did anyone else have this same problem?
Larry-L posted Sun, 02 February 2003 at 7:08 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=326693&Start=37&Sectionid=1&WhatsNew=Yes
I just used this process for my latest posting. I had the same results as you in past work until I figured out that I skipped a setting. I forgot to check the "material on" option in the "atmosphere" setup. I realized I had to set everything exactly as it is in each tutorial picture. Viola! it worked, so I experimented until I got the effect I wanted. Check all your steps carefully.
